BWA
(344 posts)
04/13/2010 08:13PM
Redline Gauge Works
Posted by: BWA
Date: October 14, 2011 05:40PM
I think I may have found an outfit that will be able to convert the internals of my TR6 speedometer and tachometer to electronic internals to work with my engine swap to a GM 3400 v6. My question is has anybody had any experience with these guys? Being that I live in Calgary, Alberta, Canada and Redline is in Southern California I want some assurance that I will get my gauges back and that they will work. I got a quote from an outfit in Michigan and they were twice as expensive as Redline.
Thanks for your time and consideration.
[www.redlinegaugeworks.com]
Byron
Re: Redline Gauge Works
Date: October 16, 2011 06:11AM
I haven't worked with them but they have a good reputation. They've been around for a while.
BWA
(344 posts)
04/13/2010 08:13PM
Posted by: BWA
Date: March 08, 2012 08:32PM
Today was an exciting day as my retrofitted TR6 speedometer and tachometer came back from Red Line Gauges. These guys did a superb job and I recommend them. The speedometer was fitted with Autometer internals and the tachometer was fitted with VDO internals. It also looked like they replated my trim rings as the set on the speedometer when I pulled it from the car was looking kind of worn. They did all this for $550.00.
Check out the finished product!
Byron
triumphtr2
tim body
St thomas ont Canada
(87 posts)
08/18/2010 10:21PM
1954 TR2 serial # TS 110 L triumph 2 litre
Posted by: triumphtr2
Date: March 08, 2012 08:46PM
Hello Byron. They look pretty nice. Can you tell me what they had to do internally to make them work? Two fifty something for new gauges you can just plug in sounds resonable to me> Thanks Tim
BWA
(344 posts)
04/13/2010 08:13PM
Posted by: BWA
Date: March 08, 2012 09:22PM
They removed the guts and made new face plates to work with the sweep of the electronic gauges.
I looked at changing out the entire set of gauges and I could not find any that looked like the original gauges so I opted for this setup. The remainder of the gauges are stock TR6 gauges.
Byron
motek
George Smathers
Spokane, WA
(118 posts)
09/12/2009 02:45PM
1967 Morris Minor (48 hp @ crank!), 1971 TR6 302
Posted by: motek
Date: March 17, 2012 03:52PM
Great solution. For another 50 bucks do you think they can put in the needle shimmy for that old-time feel? LOL
Edited 1 time(s). Last edit at 03/17/2012 03:53PM by motek.
