Aerowing extrusions ?
Date: October 26, 2011 07:07PM
You know-miniturized wing section ? Up to say 2" front to back. Hot-wired structural foam, extruded plastic or aluminum ? Looking for maximum lift to drag ratio. Need to function with hi chord angle change,(articulated). I'm alluding to use as grille work that adds downforce. Thanks, roverman.
Edited 2 time(s). Last edit at 10/27/2011 07:57PM by roverman.
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Re: Aerofoil extrusions ?
Posted by: Bill Young
Date: October 27, 2011 08:31AM
Art, not a true air foil, but should give some downforce depending on the angle it's mouted. As usual more angle more downforce and more drag, it's always a trade off. [www.aircraftspruce.com]
Date: October 27, 2011 08:42AM
That's similar to what I used as supports for my wing. Also, check out the model aircraft suppliers. I'm pretty sure you can buy leading and trailing wing edges and they should be about the right size for your application.
JB
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Re: Aerowing extrusions ?
Posted by: Preform Resources
Date: October 28, 2011 11:19AM
Art, I think you're wasting your time/energy etc. on that one , a front air dam will produce more downforce easier
like Dave Townsend did on his B(check his posts).
Dave Craddock
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Date: October 28, 2011 12:09PM
Dave, take a look at the drawing of what Art is planning, [forum.britishv8.org] the radiator will be in the rear between the tail lights. The aero effect he wants would add downforce in the rear, hopefully making a higher mounted wing unnecessary.
Don't know of anyone with a front air dam to fit a Jensen Healey do you?
Edited 1 time(s). Last edit at 10/28/2011 12:10PM by Bill Young.
Date: October 28, 2011 02:54PM
Clan, Huffaker and Delta both do. I will run "somethig" on the front, including perhaps an air inlet to oil cooler and brakes,(former turnsignal surrounds). Cheers, roverman.
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Date: October 29, 2011 11:21AM
Rear rad, good idea,how are you ducting air in to the engine compartment /rad??
BTW; we did an scca f-prod jensen healy body kit for a customer he ended up broke from the stock market and
I ended up with the moulds, they were pretty radical for a production car(pushing the rules). Unfortunately I have no pictures of the completed model but if you're interested I'll take shots of the tooling.
Dave Craddock
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Date: October 30, 2011 06:12PM
Art, I found some pics(Iknew I had some!)fender models are done and we were developing the front air dam assy,
rear wheel arch development, as you can see our plan was to allow the pumping air from the tires to exit out the rear of the fenders, from the side the wheel arch appeared the same as the stock wheel arch, the fenders covering 120degrees of the tire from the top.
Dave Craddock
(1365 posts)
Date: October 31, 2011 02:40AM
Dave,
What would it take to produce a set of those flares?
Thanks
Re: Aerowing extrusions ? Still need.
Date: October 31, 2011 11:22AM
Or Dave....maybe (2) sets ? Nose of car will be very similar to David Townsends' "photoshop".I'm not sure the engine needs air, just coolant. The hood will get hot air exits as needed, "maybe" a Hemi "shaker", oem. scoop/ backwards ? Air to rear radiator= "Kamback"/low pressure area, powerful fans, belly pan and "maybe" diffusers to air inlet. How much track width over stock ? Fred, I'm thinkin-your scheemin for a 32 valve JH ?? Jensen Healey's are kind of the "Edsels" of this forum. Let's change that ! Cheers, roverman.
Edited 2 time(s). Last edit at 10/31/2011 11:31AM by roverman.
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Date: October 31, 2011 06:59PM
PM sent you'se guys.
Dave
