Roll Bar tubing bender
Date: November 02, 2011 01:53PM
Clan, I"m looking for real value in a proffessional quality bender. I'm considering "Tube Shark" model #'s TSA-2-1-0004 or TSA-2-1-0002. Both are air/hydraulic. Anyone have suggestions ? Thanks, roverman.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Re: Roll Bar tubing bender
Posted by: tr8todd
Date: November 03, 2011 06:20AM
I have a JD Squared bender and it works great. You can hook up an air/hydraulic cylinder to it or just use a big pipe for leverage to bend. 1.75"X .120 gives you a good workout. Anything smaller bends like butter. The key is to have a good solid base and lots of room. I use to have a stand mounted on the shop floor, but it's a pain moving everything else out of the way to use it. Now I have holes drilled in the deck of my open trailer to mount the stand to. Lots of room and portable.
Re: Roll Bar tubing bender/ tubing notcher ?
Date: November 03, 2011 11:27AM
I have heard JD is the #1 seller. You have a portable compressor for the trailer ? Should also mention, I need a tubing notcher. The "Lo-Buck" unit I bought, is worthless. Thanks Todd, roverman.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: November 05, 2011 09:19PM
I never bothered to hook up a cylinder on my bender. Just slide a big pipe over the handle and let er rip. I have used a JD squared bender with an air powered cylinder and I could get used to that in a hurry. Kind of like shoveling your driveway for years and then buying a snow blower. That being said, I do have a nice portable air compressor. As a plumber, I need it to do air testing of plumbing systems and for blowing out irrigation systems and winterization of cottages and such.
Re: Roll Bar tubing bender, die $'s are the real killer
Date: November 11, 2011 04:27PM
Ok, so a Model # 32 it is. Now the bitter pill, die prices, around $300. set, average. Why not buy the "biggest" diameter, you plan to use and tubing "shims" for smaller tubing ? I've heard of this done(no pictures), but what if ? roverman.
(1365 posts)
Date: November 14, 2011 02:00PM
I have the JD bender as well and it works great.
It is pretty traumatic to have to buy the dies for each tube size and bending radius.
I never thought to try sleeving a larger die. But it should work.
Like Todd says the bigger tubing gives you a pretty good workout.
I put an actual air cylinder on mine not the air over hydraulic unit that is normally used.
You can't use it to power the bender it's just an assist. But it does reduce the effort dramatically.
Re: Roll Bar tubing bender, got details ?
Date: November 15, 2011 01:46PM
What diameter on that air cylinder ? Obviously with a 2 stage compressor peaked at 175 psi, its not going to push like 4k psi hyd. ? Pack thinwall tubing with sand, for use without internal mandrel ? Thanks, roverman.
Edited 1 time(s). Last edit at 11/15/2011 04:12PM by roverman.
(1365 posts)
Date: November 15, 2011 04:42PM
I use a 2.5" air cylinder. My air compressor is set to 125 psi but you still need a regulator to step it down. Usually start at 20 psi then go up from there otherwise it can push you around pretty good. I built a dump valve from an old natural gas shutoff valve so that you can release the pressure to reset the ratchet quicker.
If I used it more the hydraulic setup would be much better but I'm too "fiscally sensitive" (cheap) to do that.
Haven't had any problems with thinwall as long as it's clean and lubricated.
The trick with your low buck notcher is to bolt it down solidly to a drill press. Use lots of cutting oil and you'll be surprised how well it can actually work.
(6468 posts)
Date: November 15, 2011 04:45PM
Just make sure you are well aligned with the quill. We darned near destroyed a chuck with one that was off a bit.
JB
Re: Roll Bar tubing bender/plasma cutter ?
Date: November 16, 2011 07:58PM
On non-chrome moly, couldn't one chalk mark the notch and use "plasma " ? My Lo-Buck notcher is shear type. Problem is 2 sets of dies are supposed to shear 6 different sizes ? Not really ! Cheers, roverman.
rampant racing
gary fraser
sarnia ont,canada
(83 posts)
03/28/2009 02:45AM
69 spitfiremk111 ford 347 stroker
Posted by: rampant racing
Date: December 18, 2011 08:45PM
gety yourself a notcher called the old joint jigger.it uses hole saws and works great.there are different companies that make them so prices vary.goodluck.
