TR7-8 windshield trim, buy windshield ?
Date: May 16, 2012 06:31PM
Where to buy? Lot's of "scalpers" ! Special tool to remove ? Suggestions ? Thanks, roverman.
Edited 1 time(s). Last edit at 05/31/2012 09:29PM by roverman.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Re: TR7-8 windshield trim
Posted by: tr8todd
Date: May 16, 2012 10:45PM
Pry out slowly starting in the bottom corners. Don't use the glass as a leverage point, or it will crack. Use a a thin slice of wood under the prying tool against the metal windshield frame and try to slide your finger tips under the side against the glass as it lifts. Even if your careful, the windshield may still break or the two layers of windshield may delaminate at the top corners. All depends on the adhesive used. Original windshields had a wire buried in the sealant that supposedly could be hooked up electrically and the resistance in the wires would heat the sealant making it easier to remove. Never seen it work in real life.
(4636 posts)
Date: May 16, 2012 11:54PM
But what a nifty idea.
Date: May 17, 2012 11:32AM
Glass is already cracked. Likely not original glass,(race car/body in white). Just trying not to ruin trim or clips. Thanks, roverman.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: May 17, 2012 05:04PM
If you ruin them give me a shout. I have a pile of at least a dozen or so sets. It's that bugger little filler strip at the top that always seems to go missing.
Date: May 17, 2012 06:35PM
How about pushing sideways that "stradle clip", center/top of trim ? I'm still having trouble getting wiper nuts off.Cheers, roverman.
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: May 18, 2012 09:07AM
If it's there. Most times it's gone on parts cars.
Re: TR7-8 windshield trim, succes at last !
Date: June 06, 2012 02:39PM
Had I only known the trim is set with RTV silicon ! I was expecting clips/ old school ? Once one end started to give, WD-40 type lube really helped losen the stainless. Used a winshield adhesive cutting tool,(worth weight in gold), to extract the glass. Now, where do I buy a polycarbonate windshield ? Onward, roverman.
