lars49 Larry Barnes Colorado Springs (177 posts) Registered: 06/11/2009 02:12PM Main British Car: 1980 MGB GM LA1 3400 V6 |
How to paint my power mirrors??
I finally found a compete set of early Miata power mirrors for the MG. The are the wrong color and I will need to paint them. The mirrors and the base are moulded plastic, but obviously I haven't a clue as to what compond. If I were to use the base/clear coat that I will be using for the rest of the car, does anyone have an idea as to how to prep the mirrors so I get good paint adhesion? Type of primer, scratch pattern etc?
Edited 1 time(s). Last edit at 10/13/2012 02:39PM by lars49. |
Re: How to paint my power mirrors??
Larry paint is an excellent primer so use 600 grit and carefully wet sand the mirrors so as to not remove the original paint. Then prime them the same color as the rest of the car and then paint them along with the rest of the car.
Cheers Byron |
