Working on my interior
Found a couple of hours last weekend to get started on my center console. Hope to finish it this weekend. Need to make the base for the storage box, make 2 transition pieces to curve up from the shifter portion to the arm rest portion, and cut a hole in the top of my trans tunnel (and finish it off) to let the cup holders go a little deeper. Then wrap it. I also made a piece to hold my stereo amp in the trunk so if I get lucky I'all get that set up this weekend too.
Here are the parts... And this is pretty much what it'll look like assembled... The sliding lid will have a padded arm rest similar to the OEM one except a bit thicker and rounded at the front to make a lip to hold when sliding it back. |
