DonB Don Bonar Prairie Village, KS (80 posts) Registered: 09/09/2011 10:06AM Main British Car: 1971 MG-B 95 GM 3.4 V-6 |
"Hidden" antenna for MG-B roadster
I'm in need of a hidden antenna for my 71 MG-B roadster. I have a very simple system (Sony DSX-S100) with 4 speakers... no power adders or other audio equipment. Amazon, EBay and others offer a huge selection. However, in reading the user comments most seem dissatisfied to Very dissatisfied with the results. Local stations (in town) fine, Highway cruising, very poor.
Common complaint/explanation is... steel body blocks the signal. Given I'm not drilling anymore holes in fenders, etc. or removing my sealed up inner splash panels.... That explanation would seem to exclude under the dash, under the rear deck panel, and the trunk. Anyone ever run one down between the transmission tunnel and the pre-formed carpet tunnel cover? Given all the previous creative solutions in this forum... got some ideas or a product for me? Thanks Don B. |
Re: "Hidden" antenna for MG-B roadster
Hello Don
I really like the way the later BMW and other vehicles combined there rear defrosters to AM/FM antenna. Obivously the rodster does not have a defroster but it could simply be done on the MGB. You would have to paint some defroster lines on the Bottom, Top, or around your front window and affix an attachment point, but it could very easily be done and I think that you reception would be better than most antennna's. Very little work needed. Here are a couple threads i did a quick search on, but it gives you the idea of what I am talking about. What do you think? No holes or drilling needed! I will probably doing something similiar to my MGB roadster once I get to the radio! [www.bimmerfest.com] [www.ek9.org] Edited 3 time(s). Last edit at 12/11/2013 09:03PM by 63BlueMGB. |
There are hidden antennas. I've not tried them but have been doing a little research. While not necessarily a scientific evaluation, this write up was interesting.
[www.gadgetjq.com] At just about $20, I'm going to try a powered one mounted just above the trans tunnel on the vertical panel to the package tray. Edited 1 time(s). Last edit at 12/11/2013 09:47PM by rficalora. |
Don, the signal from an antenna is extremely weak and needs almost nothing in the form of a conductor, however the lower the resistance, the better. So to that end, a very fine single strand wire can be taped to the top edge of the inside of the windshield using a premium quality clear adhesive tape. Silver is slightly better than copper and carbon fiber is 2/3 the resistance of copper so significantly better but somewhat difficult to terminate.
The length of this conductor should be an even fraction of a wavelength, or in this case the same length as a fixed length FM antenna. A small coaxial cable can go from there to a signal amplifier or to the receiver. If it is grounded to the windshield frame, the frame becomes an additional antenna element. You can try it both ways and see which works better, the shield does not have to be grounded on this end. The OEM's used a balanced bipole here, cutting the length in half and connecting the center conductor to one and the shield to the other, with a center feed. You can do it either way, but getting the coax up to the center of the windshield gets a little messy. For the single element it can run up inside the hollow door seal weatherstrip bulb. Jim |
BMC Brian Mc Cullough Forest Lake, Minnesota, USA (384 posts) Registered: 10/30/2007 02:27AM Main British Car: 1980 MGB '95 3.4L 'L32' SFI V6, GM V6T5 & 3 |
We placed an internal antennae/aerial in the last GT up the glass. No reason a person couldn't do this on a convertible as well although it would be more noticed unless placed behind the door seal that is mounted to the glass.
-BMC. |
Hi Fellows!
Thanks for the ideas... I combined a couple suggestions and it's working fine in the garage... I used Brian's suggestion of a small dia. wire (22 gauge coated magnet) attached to a simple short antenna lead from O'Rileys for under the dash. After a bit of calculation, selected 34" for AM/FM wave lengths. Initally tried to tape to inside of windshield glass but couldn't make it look semi-professional in appearance (after routing thru door seal rubber). Bill Davidson came over and suggested I tape it under the lip of the padded dash crash rail... and it works great on all local stations... we'll see on the (yet to be) first road trip. Can't be seen, up as high as I can go (other than windscreen) and not under any steel body. We'll see Thanks guys Don B. |
