Goto Page: Previous123Next
Current Page: 2 of 3
63BlueMGB
Nick B
Kansas City, Mo.
(96 posts)
01/16/2011 05:17PM
1963 MGB
Re: Need tips for vinyl-covered fiberglass interior trim parts
Posted by: 63BlueMGB
Date: April 20, 2014 07:06AM
I finally made it around to thumbing through all the sub-topics and was suprised to see somebody else using this stitch, I used that stitching to awhile ago to solve a problem with some of my interior pieces that I have been making when I havent been able to get out side and work on my car. My problem was the spray adhesive wasnt holding my vinyl to my covers and the design I layed agaist it and everytime it sat for awhile it would pull away flat plus the vinyl I bought was to thick for my application so I came up with a solution to my problem instead of starting over and making new pieces. This stitch can be used to solve multiple problems.
The Baseball stitch can be used as well but it is a little more time consuming, and IMO it is better used when sewing to pieces of material together so you get a better seem and looks alot cleaner
(4637 posts)
Date: April 20, 2014 03:52PM
Thanks guys! I'm at my mother-in-law's for the weekend but I stretched vinyl over the driveshaft tunnel before I left home, and then I brought the part along so I could do the stitching here. Here's how it turned out:
I'm generally pleased with the results, but they're far from perfect. I need to improve my techniques. Here are some notes:
Vinyl soaks up a lot more contact cement than the (closed cell foam) padding. If you're applying the adhesive with a brush, it's hard to work quickly and hard to get an even coating. Then, with some of the applied adhesive a little too dry and some of it a little to wet, when you try to apply the vinyl to your part, getting a smooth application is even trickier than it ought to be. A heat gun helps with rushing an area to the dry-enough stage. If adhesive gets too dry, you have to carefully apply just a little more. I ended up using up my quart of cement, so I'll have to buy more. I'm also thinking of investing in a spray gun for the transmission tunnel (and any future parts.) So, I didn't end up with as even a stretch as I wanted and there are one or two small wrinkles in the vinyl, but not too bad.
In the small but deeply concave areas on both sides of the parking brake lever, I added stitches right away because I was concerned the contact cement might pull loose. Generally though, I think the vinyl looked "tighter" an hour after application than it did right away. The padding feels pretty luxurious.
I cut some of my darts too deeply. I need to be more careful next time. Maybe I should punch round holes somehow and just snip up to them.
You can see in the photos that I have a LOT of stitches on this part. My theory was that the stitches should hold the vinyl tight over the whole part even if the contact cement were to totally fail sometime in the future. Two needles passed through each of the 500 holes I pre-drilled in the fiberglass, so by my count that's 1000 stitches. That said, the stitching went remarkably quickly. You can't put a stitch out of line or in the wrong place if the wholes are drilled in straight rows. Incidentally, I drilled 5/64" holes on 5/16" centers over the hole part. On my test piece I had drilled 1/16" holes, but they were too tight for comfortable hand stitching with the needles I had selected. In retrospect, I'm really glad I decided to stick to one hole spacing everywhere because it helped me find the holes and establish a rhythm. Oh, BTW, I really really like the pre-waxed nylon thread I got from Tandy for this project.
Nick, I'm not certain if we're on the same page about stitching or not. I'm using thicker thread anyhow, so that gives a somewhat different appearance. As for the stitch... I used to one shown on the bottom of this sketch: [4.bp.blogspot.com]
(4628 posts)
Date: April 20, 2014 09:31PM
Wow. Your spartan interior just got a whole lot fancier. :)
Grant70B
GRANT Matthews
La Conner, Wa
(6 posts)
02/24/2013 10:38AM
1970 MGB Roadster V6 conversion 3.5L
Posted by: Grant70B
Date: April 23, 2014 08:35AM
Curtis
That really looks good, should be a nice addition to your cars interior.
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Posted by: Preform Resources
Date: April 23, 2014 11:09PM
Curtis, looking very good , I think everyone will be learning something from your experience.
Dave
rporter
Richard Porter
(16 posts)
03/22/2010 07:39AM
Posted by: rporter
Date: April 25, 2014 07:55AM
I have used weldwood HHR with great result. Brushing works best for me. 3m has not worked well for me.
(4637 posts)
Date: April 29, 2014 05:26PM
My transmission tunnel trim project is pretty much complete now - except I'll add an aluminum wear plate next to my throttle pedal to overlap, clamp down, and protect the vinyl from wear.
What have I learned since my last post?
Contact cement is easier to apply with a paint gun, and when you spray it on you use less cement. The guys at S&S Upholstery here in Longmont tell me that they leave contact cement in their gun year round, and it never clogs or needs to be cleaned out. S&S also advised that any "bubbles" in my vinyl application would likely disappear when the part gets hot. "Just leave it in the sun for a little while." Sure enough! Their tip on darts is just to cut them less deeply and rely instead/more on the stretchiness of the vinyl. Darts on my second part turned out much better than on my first part.
In fact, the whole part turned out a little neater. My vinyl stretching team is practiced now. We're three people: myself, my wife, and our dear neighbor Justine who lives across our back alley from us. The application needs to be divided into reasonable size segments. We start by test-stretching the vinyl over the fiberglass part to see where they will need adhesive, and marking the back side of the vinyl with Sharpie. Then we mask and apply contact cement to the matching surfaces. Suppose the segment we're doing is triangular except that it wraps over a radiused edge... one side of the triangle gets lined up as a starting point. Then, one person is responsible for holding all the excess vinyl up (because it will GRAB if it's given the chance). A second person presses vinyl down against the fiberglass (and landau pad) bit by bit, working across the triangle. The third person's job is to tug and stretch the vinyl as necessary.
Avoid using any sort of clamp at all; in this project they weren't necessary and the one or two places I tried to use them just gave me crushed areas that were slow to rise back up.
So now I'm thinking about door panels. Before I dive into that, I'm scheming about ways to trim around the door latches (instead of using MG's plastic trim pieces), about more robust door pulls, about custom window crank handles, and about recontouring the door cap rails a half inch taller so they better hide the window seal and clips from view and also make it more comfortable for me to rest my arm when the window is down.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: April 29, 2014 06:24PM
Hope you know, Curtis, that you're starting to add weight......
(4628 posts)
Date: April 29, 2014 06:34PM
Wow, that is very nice, Curtis! I guess the door panels & kick panels are next. :)
(6588 posts)
Date: April 30, 2014 11:42PM
There are some chromed metal door pulls that are quite sturdy, I have them in my car. Must have come from the '67.
(4637 posts)
Date: May 02, 2014 04:40PM
Now that I've had time to think about it, I'm leaning toward simply building a minimalist door pull feature into the new door caps. Just some sort of dent you can get your finger tips into. I took one of the old door caps off to have a look. I'd forgotten how dense they are. Replacing them with hollow or foam filled caps might almost be enough to offset the weight of upholstering the door cards.
I've been thinking about stitch patterns. Is this too much?
(Imagine this layout but in black stitches over black vinyl. Where you see white, that's just paper.)
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Posted by: Jim Stabe
Date: May 02, 2014 09:03PM
You better be careful, you may have to tie the car down if it gets breezy.
(4637 posts)
Date: May 03, 2014 03:56PM
I got a long way to go!
I saw a magazine article the other day about Volkswagen's GTI model. The article mentioned how light the first-gen GTI was. At 1945 pounds, it was about four hundred pounds lighter than a contemporary MGB roadster. Wow.
63BlueMGB
Nick B
Kansas City, Mo.
(96 posts)
01/16/2011 05:17PM
1963 MGB
Date: May 04, 2014 08:35PM
Curtis,
Looks really good! Here is my door panels that I have made for my car, I really like the idea of fiberglassing them to save on weight.
(4637 posts)
Date: May 04, 2014 10:35PM
Nice! I like the way you've carried the theme from panel to panel.
I ordered a mess of plastic clips from Moss the other day. I'm curious to see how well they'll work with panels that are much thinner than usual.
(4637 posts)
Date: July 11, 2014 12:29AM
Following up, I've molded a pair of custom door caps out of fiberglass. They're not as light as they could possibly be, but they'll work.
Caps and cards are pre-drilled and are ready to cover with foam and vinyl.
(I decided to use 1972-model MGB pull handles, mounted parallel with roll cage tubes.)
(6588 posts)
Date: July 11, 2014 10:05AM
Very nice work Curtis.
(4637 posts)
Date: July 18, 2014 09:25PM
This project is taking too long!
(First door card now covered in vinyl. Door cap just padded at this stage.)
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Date: July 19, 2014 02:31PM
Curtis, I probably missed it somewhere,,, but what kind of sewing machine are you using ??
Dave
(4637 posts)
Date: July 20, 2014 12:01AM
Over 1000 stitches per door panel, all hand-stitched by two-needle saddle stitch method.
I finished and installed the passenger door panel today, only to discover the door lock on that side would no longer latch. Lisa said she'd prefer her door to be latched while we're driving around Colorado Springs this week, so for the time being I adjusted the striker plate outward. Might rethink that after the meet. Covering the door caps will have to wait too.
