Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Heres how the hood mechanism works
Posted by: Jim Stabe
Date: July 14, 2015 03:43PM
I wanted a forward tilting hood but I couldn't use a simple hinge because the front of the hood has a curve to it. The hinge point would have had to be forward of the furthest forward part of the hood to work, if not the front edge of the hood would just push down on the top of the grille and not open.
Some Saab's and BMW's have hoods that move the whole hood forward and up to get it in front of the grille and then you lift the hood to the vertical position. I have also seen similar hinges used on custom pickups that have been converted to forward tilting hoods. So here is the hinge mechanism.
The tube is a 1" thin wall steel with bronze bushings pressed into each end. It pivots on pins supported by brackets screwed to the car. There are machined aluminum arms that clamp onto the tube that have heim joints that attach to brackets on the hood. Attached to the arms are bent pieces of 1/4" aluminum that act as stops to keep the hood from rotating too far forward. The passenger side arm also has a gas spring that pushes the hood forward when the latch is released.
This is what the hood looks like when the gas spring has pushed it forward and the hood has rotated up and forward on the pivot arms.
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Re: Heres how the hood mechanism works
Date: July 14, 2015 03:53PM
At the rear of the hood are two rollers (from a BMW) that engage fabricated brackets attached to the foot boxes. These guide the rear of the hood down and back and lock it in place when it has fully seated to the rear.
You can see the wheel of the BMW roller starting to engage the bracket
Here is the hood raised to the vertical position. You can see the brackets on the hood frame that attach to the heim joints on the pivot arms.
NCtim
Tim Shumbera
Western North Carolina
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: July 14, 2015 05:04PM
That's quite a bit of engineering there.
(4637 posts)
Date: July 14, 2015 05:12PM
Excellent!
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Posted by: Preform Resources
Date: July 14, 2015 05:58PM
Great work Jim !! as per usual,,,,, but still Great work !!
Dave
(6590 posts)
Date: July 15, 2015 12:50AM
Looks good, what are you using for a latch?
Other than differences in the layout that is very much like my hood mechanism. I found the cross rod to be a necessary element.
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Date: July 15, 2015 02:02AM
The latch is from a BMW also. It is quite small and has a horseshoe shaped piece that attaches to the hood that engages the latch. It doesn't have to be very big since there is not much pressure trying to open it. All it does is keep the hood from moving forward. I'm going to put it on tomorrow and I'll take a picture.
(1389 posts)
Date: July 15, 2015 01:47PM
Just like everything else on this car.
Very nicely crafted Jim!
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Date: July 15, 2015 06:49PM
Here is the latch from a BMW, not sure which model but it had a forward tilting hood. All the ones with the forward tilting hood use the same one. It is a nice compact unit and I picked up the cable release also
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(110 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Posted by: WernerVC
Date: July 17, 2015 11:17PM
The hood mechanism is from a 1987 to 1993 BMW 320i.
I used to have the 1993 version. It had the first edition fuel injection from Bosch.
Werner
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Date: July 18, 2015 02:40AM
I think it must come on other models as well. The car it came from was bigger than a 320i
mstemp
Mike Stemp
Calgary, Canada
(224 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: July 18, 2015 03:28AM
My 76 BMW 530i had the same setup. Think all 3, 5, 6 and 7 series cars had similar till mid 90s.
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Date: July 22, 2015 07:26PM
I took a picture of the horse shoe shaped piece that engages the latch. It is quite small but if it holds a BMW hood closed it will certainly hold mine.
(6590 posts)
Date: July 23, 2015 10:32AM
Should do fine.
I'm not even putting a latch on mine, but trusting in the hydraulics to hold it shut. I've had a gage on the pump for 2 weeks now and it still has a couple hundred pounds of pressure on the close line so I think it'll be OK. Based on experience with Dan B's TR4, if the latch isn't there the hood will just rise a couple inches in the rear to equalize pressure, and it uses a simple hinge. Where the front of the hood has to lift first it might not even rise at all.
(4629 posts)
Date: July 23, 2015 12:21PM
That is just too cool!
Ted Lathrop's TR6 doesn't have a latch, either. He says it lifts a bit around 135. :)
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Date: July 23, 2015 12:37PM
I'm anxious to drive the car with the hood on and take some differential pressure measurements above and below the hood to see how much lift it is creating.
