(6569 posts)
Trick for cable ends
Date: November 25, 2015 02:06PM
Came up with something new this weekend while working on Dan's TR7/1UZ conversion. Ever need a heavy cable end in a particular size? With a hydraulic press, some copper tubing, and a drill press it should never be a problem. Strip the wire back an inch or better, cut a piece of tubing the same length, slip it on the wire, stamp it down flat in the press and drill your hole in the end. Better than the ones you buy already made up. You can dress it up to look better if you like in various ways. The bigger hole you need the more you flatten it out, etc. But that's the basic idea and it works great. A little dielectric grease when attaching it is always a good idea.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Trick for cable ends
Posted by: ex-tyke
Date: November 26, 2015 08:55AM
Worth the extra effort to solder the joint too!
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
1966 MGB V6 1994 Camaro 3.4L 60V6
Posted by: Charles
Date: November 29, 2015 03:13PM
Just make sure it is acid free solder.
kstevusa
kelly stevenson
Southern Middle Tennessee
(986 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: November 29, 2015 03:37PM
Charles, we used natural and organic aromas when we solder . just a cloud of smoke, :-)
