Keith Keith Tanner Grand Junction, Colorado (92 posts) Registered: 10/31/2008 01:45AM Main British Car: For the purpose of this forum, 1972 MGB GT 5.7l Chevrolet LS1 |
Mk1 Golf (aka Rabbit) fender flares
Poking around, I came across this car:
[www.entune2000.co.uk] It apparently uses fender flares (in the rear at least) from a Mk1 Golf. Here's all the information I have: "replacement steel arches as fitted to the VW Golf GTI, Passat or Bora" Does anybody know of this modification? I like the looks of them. |
Re: Mk1 Golf (aka Rabbit) fender flares
Keith, it's pretty much the same as using the Dodge Omni flares, just cut them from the VW body and weld into the B panels. They come from the early 80s Rabbits and Golfs, pretty much the same as the Omnis. You've got to go pretty far back, before the full front and rear plastic bumpers to get flares that reach all the way down to the rockers front and rear. IIRC the VW flares have a bit wider outer lip than the Omni items, but not by much. Repair panels for the rear arches are stocked by this company [www.rustrepair.com] but I don't know how large or compele they are. I'd say the parts for the 2 door bodies would be better for flares. They don't show anything for the Omni.
rustrepair.com has Mk2 and Mk3 parts, but I couldn't find any Mk1 stuff. I think I'll begin with picking up a couple of junkyard fenders that are here in town and cutting them up.
rficalora Rob Ficalora Willis, TX (2701 posts) Registered: 10/24/2007 02:46PM Main British Car: '76 MGB w/CB front, Sebring rear, early metal dash Ford 302 |
I'm doing this stuff for the first time, but I'm seam welding mine. If you spot weld I'd think moisture would get in over time.
I picked up some Rabbit fenders over the weekend.
![]() I'll cut them out and do a rough fitting soon. The rears looked really good, but the yard wanted $100 each to torch them out! |
What's the spread at the bottom? I'm using Omni/Horizon flares... they came from a mix of cars & a couple were NOS replacement (non-OEM) fenders & found that there was a lot of variability... some measured 27" across; others 28" & one was close to 29". Front & rear were closer to 28.5" on my car so the 27" ones required more work to get them to fit well. Curious what you find with the Rabbit flares. Also, how much they end up extending past the body edge.
harv8 Martyn Harvey Waterloo, Ontario, Canada (179 posts) Registered: 10/23/2007 10:09PM Main British Car: MGB Rover V8, TVR Chevy V8, MGB GT Ford V8 |
Carl, any idea what spoiler was used on the rear deck of the MGB with Rabbit flares?
Well, good luck on that. I also think that it's a good mod that your car could have. Meanwhile, you can check out this How to Replace Fender DIY to guide you through out that modification.
