MGB SS
Joe Schafer
Central Michigan
(150 posts)
10/23/2007 06:46AM
1971 Mgb 1991 5.0 Ford
Painting Smith gauge needles
Posted by: MGB SS
Date: August 29, 2018 08:06PM
Has anyone taken the glass off the stock smith gauges to paint the needles Red?
My new gauges have Red needles but thinking I might want to keep the square oil pressure gauge in the new dash
(6716 posts)
Re: Painting Smith gauge needles
Date: August 30, 2018 07:46AM
It's pretty easy Joe, the bezel spins to where the tabs line up with the notches and it all comes apart. Worst thing is when the seal has decayed and sticks it all together. On some occasions I have had to pry the tabs out but that's best avoided if possible, maybe wick some solvent in around the edges to loosen things up. The needles will come off with a couple of small prybars to evenly lift, protect the faces of course. Lastly, be scrupulously clean going back together. I've used o-ring material for new gaskets.
(4705 posts)
Date: August 30, 2018 08:59AM
Did you find an oil pressure gauge, Joe?
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1168 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: August 30, 2018 09:31AM
Quote:
It's pretty easy Joe, the bezel spins to where the tabs line up with the notches and it all comes apart...
That method doesn't work well with a square oil gauge.
(4705 posts)
Date: August 30, 2018 08:00PM
Or even a rectangular oil gauge. ;)
(6716 posts)
Date: August 31, 2018 09:38AM
Huh. You learn something new every day I guess. And bending the tabs out without deforming the bezel is a bit of a challenge too but maybe you could clamp it in a vise with smooth jaws first.
MGB SS
Joe Schafer
Central Michigan
(150 posts)
10/23/2007 06:46AM
Posted by: MGB SS
Date: August 31, 2018 06:40PM
Ah I see you moved me, I have to see if I can find my original one to experiment on, if not I will be looking for a rectangle oil gauge
MG four six eight
Bill Jacobson
Wa state
(326 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: August 31, 2018 07:09PM
I painted mine to match my white faced VDO gauges. For the lettering/numbering I used black rub on letters/numbers from an office supply store.
I'm pretty happy with the results, even put "VDO" on the gauge face!
Simon Austin
Simon Austin
Surrey, British Columbia
(107 posts)
10/23/2007 01:44AM
1977 MGB V8 / 1970 MGB GT V8 project Rover 3.5 / Rover 3.5
Posted by: Simon Austin
Date: September 01, 2018 10:20PM
The oil gauge bezel tabs will bend but be very careful. Only bend as far as necessary. Once the bezel is off, the gauge will come apart.
I painted my needles when I created white-face dials for the OEM gauges.
MGB SS
Joe Schafer
Central Michigan
(150 posts)
10/23/2007 06:46AM
Posted by: MGB SS
Date: September 02, 2018 08:04PM
cool thanks for the info, when I get a gauge I will give it a try these are the gauges to try to match
