NAS1966
Norbert Sliwinski
Monroeville
(28 posts)
08/11/2012 05:20PM
1973 MGB GM 2.8 V6
License Plate Light
Posted by: NAS1966
Date: January 05, 2019 11:22AM
Started "frenching" the rear license plate. There is very little room to mount a light above the license plate. I am thinking of an LED strip? Any ideas?
(2603 posts)
Re: License Plate Light
Date: January 05, 2019 06:39PM
I used a lighted license frame like this one. [www.speedwaymotors.com]
britcars
Phil Ossinger
New Brunswick, Canada
(329 posts)
02/02/2009 07:58PM
1977 MGB Roadster, Rover 3.5 ADVENTURE BEFORE DEMENTIA!
Posted by: britcars
Date: January 05, 2019 11:28PM
I used something similar to these.
[www.ebay.com]
[www.autozone.com]
Jim Stabe
Jim Stabe
San Diego, Ca
(712 posts)
02/28/2009 10:01AM
Posted by: Jim Stabe
Date: January 06, 2019 02:18AM
I used one that has both license plate light and 3rd brake light [www.honestcharley.com]
EBay has some better prices [www.ebay.com]
Edited 1 time(s). Last edit at 01/06/2019 02:37AM by Jim Stabe.
greeneyes84
Tyler Cruise
(8 posts)
01/04/2019 07:27AM
Posted by: greeneyes84
Date: January 07, 2019 08:28AM
Are they easy to install?
Jim Stabe
Jim Stabe
San Diego, Ca
(712 posts)
02/28/2009 10:01AM
Date: January 07, 2019 10:54AM
All the wires you need to connect to are right there in the trunk on the other side of the rear panel.
v8mgb
Jim Miller
(85 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Posted by: v8mgb
Date: January 31, 2019 01:19PM
I used these license plate bolt style. Only needed 2 mounted on the top.
[www.ebay.com]
(5776 posts)
Date: January 31, 2019 02:04PM
The trouble with those is that so far as I know at least, nobody makes a decent connector that is small enough to fit through the nut. So if you have to remove the tag it means cutting the wires.
There is a remedy that just occurred to me though. Cut a slot in the nut wide enough for the wire to slip through. It still doesn't get you past the holes in the body and the plate itself but it's astep in the right direction.
kstevusa
kelly stevenson
Southern Middle Tennessee
(913 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: February 01, 2019 07:00AM
You could use the Posi-Tap Connectors and just unscrew if needed. When I sold my B, just removed the screw on connectors and gave them to new owner. Piece of Cake. Posi-Tap is a Brand of connectors to do not require crimp or solder.
Scott68B
Scott Costanzo
Columbus, Ohio
(540 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: February 01, 2019 10:00AM
I used nylon nuts and bolts to hold the license plate mount on and cut a groove in the bolts to run the wires through. I have connectors that allow me to remove the license plate if i have to. It's a little bit of a hassle but I didn't have to drill any holes. It's worked for over 10 years now.
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
1966 MGB V6 1994 Camaro 3.4L 60V6
Posted by: Charles
Date: February 24, 2019 09:05PM
I used something like these shown, when I changed the plate I just cut a slot in the plate and did the same for the new plate.
I like my tag lights a little on the dim side, I don't know why I just do.
regards
(3672 posts)
79 MGB, Buick 215
Date: February 25, 2019 08:55PM
So the cops can't read it when you fly past? ;)
7399MGM
Norbert Sliwinski
(9 posts)
08/04/2018 08:01PM
Posted by: 7399MGM
Date: March 06, 2019 04:10PM
Just bought the lights Jim Miller recommended - they certainly do the trick...
(5776 posts)
Date: March 06, 2019 04:56PM
I like Charles' idea of notching the plate. You'd only need a 1/16" wide notch.
(3672 posts)
79 MGB, Buick 215
Date: March 08, 2019 09:29AM
We rarely change plates here in TN. First they figured out how much money they would save by doing away with the front plate, then they went to yearly stickers, then no more embossed plates.
I would have to dig thru the registration, but I am sure my truck & MG have a dozen or more year stickers stacked on top of each other.
Kinda brings an end to running year of manufacture license plates.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1065 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: March 09, 2019 10:02AM
Quote:
...have a dozen or more year stickers stacked on top of each other....
That's how they do it in Ontario, too .....now only if they'd drop that ugly front plate and go with a single rear!
