BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (6587 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Electric windows
I saw the photo of the dor of Martyn Harvey's project and he seems to have a different sort of electric window setup. So what's the latest?
Jim Here is the link to Rob's electric window thread: [forum.britishv8.org] Edited 1 time(s). Last edit at 12/17/2017 10:59AM by BlownMGB-V8. |
Re: Electric windows
He used a unit from some sort of Toyota pick-up if I recall (could be way off on that, just what I seem to recall).
I got the AutoLoc ones (PW5500). The motor can be remoted. Haven't installed them yet; hope to soon. Will let you know how they work out if you're not past this by then! |
harv8 Martyn Harvey Waterloo, Ontario, Canada (189 posts) Registered: 10/23/2007 10:09PM Main British Car: MGB Rover V8, MGB GT V8 Rover 3.9, |
I thought I'd try this set up from Victoria British. It was quite inexpensive and on sale when I bought it some time last winter.
It is a very easy installation. I hope it's going to be reliable. |
Any photos you guys could post would be a big benefit.
I have the ones from BV. I will dig them out, take several photos for you today Jim, and post.
That's the sort typically referred to as a "Universal" kit by the Hot Rod vendors isn't it Calvin? I read mixed reviews on those when I was researching. Most folks with smaller/lighter windows seemed to think they worked well; folks with heavier/older cars & those with tight cranking regulators had trouble with them. I'll be interested to hear how they work for you.
This one came from British Victoria. I don't know if it will work for the TR6 at this point. It hasn't even seen a door yet. It will be interesting and will let all know how it goes. Probably will make better parts for it it the end, or even go a different route.
Taiwan made Hmmm! |
MGBV8 Carl Floyd Kingsport, TN (4628 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB Buick 215 |
Interesting that y'all are adding weight with this mod.
A local club member plans to do track days at VIR. He welded in a a really tall roll bar & stripped out the door guts. It's amazing how light an MGB door is without the window glass & regulator! Hmmm. :) |
Agree on added weight. Just need to make another car for autoX ("dreaming")
I know if I was single and didn't have a wife, my build would be way lighter without all the ceature comforts added, so to even make the build, needed to sell her on the idea first, but had to add what she wanted. Have learned if wife is not happy, no one happy! :-) |
The AutoLoc PW5500 I'm bought (yet to install) keeps the glass, but loses the regulator... The replacement track, motor, cable is probably 1/3 the weight of the MG regulator. But, i think the glass is where the real weight is.
Quote: Words of wisdom for all husbands. Know it, learn it, live it! Rob, You're right. Hmmm, I don't use my windows much anyway, so maybe the hot ticket would be your lightweight power windows plus lexan. End result, lighter & that window crank handle will be out of my knee's way for good! |
When I worked for Volvo Trucks (and "WhiteGMC"), we were building such wide truck cabs that there was no possibility a driver could manually roll down a passenger-side window without standing up and walking over. We always offered two power-window options: you could get a motor on just the far-side window or on both. (On the earlier model trucks you could get either air or electric windows - so actually four options!)
An MGB or a TR6 is so narrow that the usual main reason for power windows is gone, at least for gorilla-armed people like me. This Sprite owner retrofitted MkI (bugeye) doors to his MkII to lose window weight: [www.britishv8.org] To each their own! |
Jahdave David Cousins Campbell, California (13 posts) Registered: 09/13/2008 02:15AM Main British Car: 1977 MGB Rover 3.5 V8 |
I used a set that I bought from Moss Europe. They work well and have been installed for 5 years now. I cannot remember how much I paid for them, but I do recall that they were an easy installation. The window regulator is now out of my way on the door. I'll post pics soon.
Bruce Mills Bruce Mills Vancouver Canada (71 posts) Registered: 11/28/2007 09:31PM Main British Car: 1974.5 MGB Roadster 3.5 Rover |
Where about are you electric window guys running the wiring into the door.
The reason I ask is I shaved my door handles and the looms I used (SS Braided door looms) failed very quickly and I am looking for a better idea Thanks Bruce |
Bruce, anytime you place wiring where it will flex you will have failures. Probably the most reliable contact for power windows and door locks is through a spring loaded contact strip such as then ones sold by Painless Performance. The windows and doors will only work when the doors are closed, but then you shouldn't need to operate them when open anyway. They make a 5 contact strip suitable for a door with electric windows, power locks, and a doom light switch. [www.painlessperformance.com]
By the way, I worked on the AutoLoc PW5500's today... no good. Channel can be cut down to fit with the motor remoted, but there's no place it'll fit... it's too big to fit between the glass & the inner door panel. I'm back to the Moss sissor type regulator as the only good alternative.
