Dustless blasting
Don't do it. Don't even think about it. Warped my panels my TR8 coupe, and left sand everywhere. The clean up at the house was horrendous. Rust started forming almost immediately. Destroyed a hood, trunk and the roof panel. Had to cut out the roof and install one of those sliding folding Webasto tops. Finding a trunk lid was easy. Finding a TR8 hood that wasn't rusted was another story, and an expensive one at that. Flash forward a year later and I'm finally ready to paint the car. Still getting sand that miraculously keeps appearing despite many many hours of hitting the car with high pressure air, multiple complete hose downs with water. Last coat of primer sealer had some sand in it. No problem, scuff it before color coat anyway. Spray color on jams, underside of hood and trunk, inside trunk, and engine bay. Get a little sand on fender tops, and tops of strut towers, no problem. Clean everything up and go back in a week later to color the whole car. First coat, great, second coat goes down as smooth as the first, and then I see the car from a different angle, sand sitting on top of the paint in a few areas. Worst spots are vertical sections at the backs of the rear fenders and along the tail light panel. I'll give it three days or so and then hit it with some 1000 grit and see if I need to give it another dusting of color. At least the car is single stage white, so touch ups will be easy. Yesterday I was watching a TV show that rebuilds old Japanese cars. They were chemically stripping a car, and the guy says something about how they know now not to blast a car as it just warps the panels. Process might be great for pickup truck frames, but not on thin paneled sports cars.
mstemp Mike Stemp Calgary, Canada (200 posts) Registered: 11/25/2009 07:18AM Main British Car: 1980 MGB Rover 4.6L |
Re: Dustless blasting
Sorry to hear iof the poor results. I thought it looked like a great method. 20 years ago I had my MGB shell plastic media blasted (used air) No warped panels from that technique. Sounds like your dustless technique still uses sand.as the media and maybe too high a pressure? What distance from the surface did you use?
Edited 1 time(s). Last edit at 09/22/2019 09:03AM by mstemp. |
Wasn't me. Actually paid a professional to do it. Spent the last year off and on trying to get it ready for paint. Saw this current stretch of perfect weather coming up so I decided to prep and paint another TR8 as well. Started sanding down that one last weekend. Sprayed the sand blasted car yesterday and the second car today. So the math works out to a year of body work on a zero rust car compared to a week on another zero rust car. To be fair, I also prepped and painted the engine bay, interior, and trunk on the sand blasted car as well as building roll bar inside it. Rolled the fender lips, and did a few other small mods. Adding the support structure for the folding roof took some serious time.
