Flares - just curious
Since Camaro's seem to be a popular source for 60* GM V6's, has anyone looked at the flares on Gen 3 camaro's (1982-1992)? They're a little smaller than Omni or Rabbit, but look to be about the right diameter & there should be plenty around. Has anyone tried them?
Re: Flares - just curious
Interesting, quite a few camaros and firebirds at the pick n pull - I've been eyeing about every car on the road as a potential donor. Most of the new stuff is only a 1/2 fender with the lower section in plastic. So far I think my increased track (I'm around 54" for track width with 245/45/17 tires) is going to have to live with sebring type flares on the back. I do like the look of cobra fronts. I think porsche 911 flares would work on the rear if you need to go wide, but they're a little pricey. I pulled some molds from a set of sebring flares - will probably just make my own. Haven't seen any pics of yours lately - how's it coming along?
Rob, I looked closely at the flares on the Camaro I got my engine from ('87) and decided that for my Midget they wouldn't work very well. The Camaro body has a lot of curve to the sides which makes the flares look quite a bit larger width wise, but if you trim that to match the rather flat sides of a MG then you either lose a lot of the width or wind up installing the flare at an angle and the "lip" around the wheel opening winds up pointing inwards instead of 90 degrees to the ground. I thought that would look a little strange.
