DC Townsend David Townsend Vermont (407 posts) Registered: 11/21/2007 12:22PM Main British Car: '78 B (almost done) 30-over SBF, dry sump |
Help removing doors
Having a hard time removing the screws that attach the door to the hinge or the hinge to the body. Granted, I'm only using my hand-held impact driver, but I thought they would at least budge. Nada. Thoughts? Suggestions?
Re: Help removing doors
A few of mine were frozen solid; drilled them & use an easy out... but i was in a hurry the day I did it. If you have time, get some penetrating oil & spray it on liberally from both sides & let it soak a day or two, then spray some more & let it soak again.
Thanks Rob. I sprayed them liberally a day or two ago and am going to have another crack at them tonight. Am also contemplating using some heat. If nothing moves, I'll be following the drill and easy out route. If this is the worst thing happens during the disassembly, I'm going to be a happy, happy, guy.
Invest in a set of Philips (cross recess) head sockets as seen here
[cgi.ebay.com] One can get a lot more leverage on the joint. |
Graham gets the prize! Inserted the biggest Phillips bit from my impact driver into a 1/2" drive socket and used my breaker bar. They cam out just like butter. Thanks! I was getting set to drill them out.
mlieb mike Lieb Dubuque,Iowa (32 posts) Registered: 07/01/2009 07:47AM Main British Car: 1972 midget |
Whats the trick to getting the fenders off my midget?
I cant seem to get at all the bolts. Any tips?I need to get the whole front end off. |
