Race Cars and Motorsports
chilipadi
Andrew Crombie
Singapore
(5 posts)
07/15/2011 10:19PM
1974 MGB GT V8 full race Rover V8 Tuscan Challenge spec
4.5l Rover V8 Race Engine Ignition
Posted by: chilipadi
Date: August 27, 2011 09:38PM
What is the best ignition system for a carburetted 4.5l V8 (Tuscan Challenge spec) race engine? Best distributor. best ignition controller, best coil, best combination?
Thanks
Drew
Re: 4.5l Rover V8 Race Engine Ignition
Date: August 27, 2011 11:20PM
I'm not familiar with the Tuscan Challenge rules, and probably most of the folks on this board aren't. Can you fill us in on the rules? Would it be within the rules to run crank-fired (direct) ignition and multiple coils?
chilipadi
Andrew Crombie
Singapore
(5 posts)
07/15/2011 10:19PM
Date: August 28, 2011 08:30PM
This is the old Tuscan Challenge spec which is basically a 4441cc Rover V8 engine with a very high spec head. I suspect the best set up is a Mallory Unilite Distributor, Master Blaster 2 coil and MSD Digital 6AL control box with Morosi 8.5ml leads but I am sure there are people on this site with much better knowledge.
One question would be- is the MSD Pro-Billet distributor better than a Mallory Unilite?
Any help gratefully received.
Drew
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Posted by: WedgeWorks1
Date: August 28, 2011 09:43PM
MSD Is better. The unilite has module issues that can burn out without any notice and well only fix is to carry a spare.
chilipadi
Andrew Crombie
Singapore
(5 posts)
07/15/2011 10:19PM
Date: September 02, 2011 01:57AM
Thanks for your input. MSD was favoured on the other sites i checked, although surprisingly John Eales' view was that none show any discernible advent age over the stock Lucas set up.
Have gone with the MSD 6AL Digital, MSD Blaster 2 coil and MSD Billet Race distributor, Moroso 8.5mm leads. Hopefully will do the trick. Living in hope that it will make a difference.
Drew
