Race Cars and Motorsports
How Fast ? correction
Date: June 06, 2012 07:58PM
TR 7 roadster, driven by Craig Leinicke, runs approx 119 mph with 108 rwhp., at the Maxton mile. Therefore, to double speed should require hp squared = 8x 108hp, or 864hp.. Got game ? roverman.
Edited 1 time(s). Last edit at 06/28/2012 01:43PM by roverman.
djw090
David Witham
Warwick UK
(115 posts)
06/12/2008 11:20AM
MGB 1974 and MG ZT 160 turbo 2005
Re: How Fast ?
Posted by: djw090
Date: June 11, 2012 11:48AM
So will a supercharged 5.0L Jag V8 fit? That should give you enough power if well set up.
Re: How Fast ? Plenty.
Date: June 11, 2012 04:07PM
David and clan, the "logical choice", is RV8. With heads and other required parts, available now for the Rover, keeping the car on the ground, should prove to be more of a problem. Cheers, roverman.
Dan Jones
Dan Jones
St. Louis, Missouri
(280 posts)
07/21/2008 03:32PM
Re: How Fast ? correction
Posted by: Dan Jones
Date: July 31, 2012 04:52PM
You're getting your calculations mixed up a bit. Squaring = 4x. Cubing = 8x.
While aerodynamic drag is proportional to the square of velocity, the power
required to overcome it is proportional to the cube of velocity. Using the
simplifying assumption that all the drag is aerodynamic, if we assume 108 RWHP
gives a 118 MPH top speed (optimally geared), it should take 526 RWHP to go
200 MPH for the same vehicle. This is a terminal velocity calculation and
ignores any time to accelerate. 864 RWHP will get you 238 MPH.
Dan Jones
Date: July 31, 2012 05:48PM
Thanks for the math. Good news is, "Mojave Air Strip" also has 1.5 mile runs,(12,000 ft. long run area). Top speed so far is approx 235 mph. The big question is, can this happen with a 4bbl RV8, all motor, with race gas or maybe E98 ? The Quest, roverman.
Preform Resources
Dave Craddock
Redford,Michigan
(359 posts)
12/20/2008 05:46PM
72 MGB V6 3.4
Posted by: Preform Resources
Date: July 31, 2012 06:17PM
Art, Mojave Air Strip, you mean Muroc sorry,I mean Edwards can be used again ?
Dave
Date: July 31, 2012 09:49PM
I'm sure it's military, so Edwards ? Mojave Speed Challenge, or such has a webbsite. They've had two events, so far. Cheers, roverman.
