Race Cars and Motorsports
Phillip G
Phillip Leonard
Kansas City
(395 posts)
02/03/2008 04:12PM
1992 MG RV8 Rover 3.5
Rover 3.5 V8 alternator
Posted by: Phillip G
Date: June 16, 2012 12:07PM
Racers,
I would very much appreciate some suggestions from past experiences ... for adding a small alternator to the front of a Rover 3.5 block/water pump. The SCCA GT2 Rover MG RV8 - running directly off a small battery - would find several benefits from a small alternator. Securely mounting the alternator and conforming to the water pump with a single belt is the goal. Too, a cold air induction filter and hosing are nearby the area for the alternator.
All suggestion - particularly simple and innovative solutions - will be much appreciated.
keep them on the track,
phillip g
Re: Rover 3.5 V8 alternator
Date: June 16, 2012 01:52PM
something like this?
http://www.britishv8.org/MG/CurtisJacobson/CurtisJacobson-F.jpg
That first view (above) is from when I had Buick 215 heads. Buick heads and Rover heads have different accessory bosses.
When I switched from Buick heads to Rover heads (like you have) I had to make a slightly longer steel outer bracket and also add a simple steel inner bracket between the cylinder head and the alternator. The inner bracket has a nut welded onto it, upon which the alternator pivots (to tension the belt.) As I recall both steel brackets are ~0.09" thick. If they were 1/8" thick they'd be obscenely overweight.
Phillip G
Phillip Leonard
Kansas City
(395 posts)
02/03/2008 04:12PM
Date: June 17, 2012 10:43AM
Thanx, Curtis,
The photos are a big help in designing some brackets for the new alterntor !
cheers,
phil
