Race Cars and Motorsports
(2986 posts)
TR 8 Update, Huffaker GT 1
Date: November 06, 2012 12:39PM
I could not find ring and pinion, lower numerically than 3.08/1. I decided to build a Yukon aluminum 9" ford, with a drag spool. This should preclude the need for a cooler, in 1/4-1.5 mile, standing start speed events. I'll be building a 4L V8, this time around. The high hp./large motor will need development time. I thing this means about 160 mph., for "flyingwedge", in April. Onward, roverman.
(2986 posts)
Re: TR 8 Update 1/11/13, Huffaker GT 1
Date: January 11, 2013 02:31PM
I ordered a Hurst Super Street shifter, through "tech" at Jeg's. This based on my input of road race usage,(M 22 box), wanting "straight" shift rods. Shifter looks fine, and then I receive the "installation kit"= + $140., and it has 3/8 spagetti, for shift rods ! This is starting to "shift" my brand loyalty. Onward, roverman.
(2986 posts)
Re: TR 8 Update, Huffaker GT 1, "PICTURES"
Date: January 16, 2013 12:31PM
Edited 1 time(s). Last edit at 01/16/2013 02:16PM by roverman.
(2986 posts)
Re: TR 8 Update, Huffaker GT 1, PICTURES
Date: January 16, 2013 02:09PM
Regarding photos above, not the best, but you get the idea. I'm not proud of the way the car has been stored, since 1985, but I'm doing a full restoration-now. Bolt-on alterations-only, to upgrade for Mojave 1.5 mile,(April 2013). Lot's to accomplish, for the April run. Cheers, roverman.
Edited 1 time(s). Last edit at 01/16/2013 02:10PM by roverman.
DC Townsend
David Townsend
Vermont
(406 posts)
11/21/2007 12:22PM
Posted by: DC Townsend
Date: January 16, 2013 07:01PM
Art,
Is the mesh on the driver's side floor over top of the sheet metal or in place of it? Hard to tell from the photo. Looks to be a great ride when completed.
David
(2986 posts)
Date: January 16, 2013 08:08PM
David, mesh is on top of original floor pan, just how Huffaker built it.Calling on our collective wisdom, how to I take care of the surface rust, on the floor, under the mesh, without removing it ? If I sand blast, I'll never get all of the sand out. Otherwise, I plan to get a lot of jollies, in this E-ticket ride. Just posted some pic's of "AC 6.1", in the Healey section. Cheers, roverman.
Edited 2 time(s). Last edit at 01/17/2013 11:57AM by roverman.
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Posted by: WedgeWorks1
Date: January 17, 2013 09:23AM
I am confused as to why you would not bring it back to Vintage GT1 specifications? If you think about it there was Slagle's coupe and convertible GT1 cars. There were probably 2 or 3 Huffaker convertibles and 2 or 3 coupes. There was one other GT1 TR8 running with them. I have not seen any of the Huffaker cars back on the track or even brought to exist? You could get away with running a 4 bolt main 4.0 liter engine to run in the class and transmission is open and so is the rear but if those parts are with the car and it is complete why not? Just my .00000999999 cents worth.
(2986 posts)
Date: January 17, 2013 11:28AM
Mike and clan. NO cutting on the car ! Maxton nose and possible belly pan, is only for straight line speed events.I have no current plans to run SCCA GT1. Putting the car back to Huffaker spec', will be very simple. Why use up the long obsolete race 5 speed or rear end ?Going the other extreme,I have no desire to compete for points in VARA, , with their restrictions. This is the "H5" car that Lee Mueller, among other's, drove for Huffaker. Cheers, roverman.
Edited 1 time(s). Last edit at 01/17/2013 05:43PM by roverman.
DC Townsend
David Townsend
Vermont
(406 posts)
11/21/2007 12:22PM
Date: January 17, 2013 05:34PM
"Calling on our collective wisdom, how to I take care of the surface rust, on the floor, under the mesh, without removing it ? "
I've great success with Eastwood's rust conversion products (they actually seem to work as advertised). They come in both aersol as well as quarts, etc. and spray on for simple application. That way, no removing the mesh, assuming you can get decent penetration spraying through it. Otherwise, I think you'll need to remove it, deal with rust, paint, replace it.
Phillip G
Phillip Leonard
Kansas City
(395 posts)
02/03/2008 04:12PM
1992 MG RV8 Rover 3.5
Posted by: Phillip G
Date: February 01, 2013 12:45PM
Art,
Thanx for the pics of your Huffaker TR8 GT1 racer !
I hope to someday see it at the racetrack.
keep them on the track,
phillip g
(2986 posts)
Date: February 01, 2013 01:29PM
Phillip, As I do yours. Cheers, roverman.
rtope
M. Ray Tope
(9 posts)
08/08/2010 01:35AM
Posted by: rtope
Date: May 14, 2013 07:07PM
In the pictures from 1-16-13, what type of Rear disk brake system was Huffaker using in the car, and what size were the rotors & calipers???
(2986 posts)
Date: May 15, 2013 05:17PM
Ray, AP Lockheed, 4 piston and 10.5" vented rotors ? I'll need to check. I'll be converting to a full-float 8" Ford rear. Trans is M22 Muncie. Onward, roverman.
(1259 posts)
What if the Hokey Pokey really is what it's all about?
Date: May 17, 2013 04:08AM
Art!
Pretty cool car. Don't know how I missed the earlier pics.
Must have been the brain damage from the pool accident.
If you need help just yell. We aren't really that far away.
I'd love to be part of putting that car back on the track.
(2986 posts)
Date: May 17, 2013 11:26AM
Thanks Fred, as Mike says, we don't see "any" of these cars, anymore. I'm really glad I saved it, all these years. Not saying I woun't, but the thought of road racing this, in SCCA, doesn't appeal to me at this time. I am determined to at least do track days and such. Cheers, roverman.
tr8
Paul MacDonald
Canada
(33 posts)
10/25/2008 04:07PM
TR8 Coupe Rover 4.0
Posted by: tr8
Date: February 09, 2019 06:18PM
Any updates on the car?
(2986 posts)
Date: February 12, 2019 12:43PM
How the time flies... I must be having fun ? It's not like me-BUT, I may have come to my senses. Put the car back as it was built, excepting with a 4.0L block. Car is dirty/neglected, but not that bad to restore. This will be blast to show and drive, just as Huffaker built it. Onward, art.
tr8
Paul MacDonald
Canada
(33 posts)
10/25/2008 04:07PM
TR8 Coupe Rover 4.0
Posted by: tr8
Date: February 13, 2019 09:13AM
Great plan, glad the car will not be modified, too unique for that.
