John Hamilton John Hamilton Navarre, FL (23 posts) Registered: 10/28/2009 11:18PM Main British Car: 1965 MGB 1840 cc MGB |
Re: TR 8 Update, Huffaker GT 1
I need to build a new engine for my MGB GT V8 road race car. Any advice on pistons, etc? Things to avoid?
Thanks, John |
What will your rev limit be, John?
Assuming you are required to use a Rover V8 (maybe Rover 3.5 only) engine, can you only use certain years? Could you use a 4bolt main 4.0 sleeved down to a 3.5 bore? |
I'm pretty sure the sleeved down 4.0 would be acceptable. Rev limit 7000. With the previous engine, 10:1 compression, hydraulic cam, I never got it fully sorted. My run group was all the big bore stuff and it was embarrassing how out-gunned I was.
Read your specific rules, very carefully. IF is doesn't say you can't ? Says no 180 cranks ? Roller cams ? Roller rockers ?
You "may" have an advantage, if they're not really savvy on your engine ? Good Luck, Art. |
Christian, thanks for that video. My car deserves no less, to be seen and heard.
Art. |
Carl Floyd, In GT-1 car is allowed 4L.Bore or stroke to get there. I called a guy many years ago had a small journal "billet:,I
Definately want now ! Avanti, fast. |
Yes, well there are C production cars and then there are GT-1 cars. 400 hp with an 85:", wb. makes for a pretty lively package.. Good news in vintage racing, driving ten-tenths, is discouraged. "IF" I make 8,000 rpm at Bonneville, 250 mph will be mine !
Note to self, bring hammer for goose bumps. |
Bonneville motor will have forged crank, Ti, rods. with Lots of rpm. TA heads with intake valves, sized for 5k. elevation. Record is 210 mph.
See you there,! Art. Edited 1 time(s). Last edit at 07/14/2025 10:48AM by ag1234. |
