MadMarx Christian Marx Germany (51 posts) Registered: 01/02/2014 11:54AM Main British Car: 1977 Triumph IMSA TR8 Group 44 Canada Rover 4L |
Nürburgring racing
I had some questions about the car regarding different tires and compounds.
I've booked a race with forecasted rain. The good thing, on Friday I could test things in dry, and on Saturday in the wet...to have a direct compare. [www.youtube.com] [www.youtube.com] |
roverman Art Gertz Winchester, CA. (3075 posts) Registered: 04/24/2009 11:02AM Main British Car: 74' Jensen Healy, 79 Huff. GT 1, 74 MGB Lotus 907,2L |
Re: Nürburgring racing
Great video's ! Looks like you're using about 5,700 as a max rpm ? Seems low for a full- worked 4L ? Car is ratio limited ? Roller cam ? Billet crank ? Cheers, Art G.
we changed the configuration of the engine.
It was a high reving engine.....but we backed off the top end power about 50 hp and lifted up the torque significantly. Much handier to drive than using high revs. But certainly the engine can do 8k technically but from the cam power stops at about 7K. Flat tappet cam, roller rockers, billet crank. Edited 1 time(s). Last edit at 10/25/2019 04:31AM by MadMarx. |
Less drag and wear. Faster opening and closing of valves= more HP and torque,(with the right cam). Art.
