Race Cars and Motorsports
John Hamilton
John Hamilton
Navarre, FL
(18 posts)
10/28/2009 11:18PM
1965 MGB 1840 cc MGB
Accusump
Posted by: John Hamilton
Date: June 13, 2020 08:18PM
Is anyone running an Accusump on a Rover V8? From reading their options, they don't have an electric valve that will operate at the low pressure these engines make.
(3075 posts)
Re: Accusump
Date: August 29, 2020 06:11PM
I ran an acu-sump on my Huffaker TR8, while learning to drive it. Manual control, ball valve. " Low oil pressure these engines make"
Got specifics ? Why would solenoid/electric valve care about low/high pressure ? Art.
John Hamilton
John Hamilton
Navarre, FL
(18 posts)
10/28/2009 11:18PM
Re: Accusump
Date: December 26, 2020 08:38PM
Maybe it's my understanding of how these work that is the issue. As a pre-oiler, the type or pressure of the valve is irrelevant. If used to prevent oil starvation during cornering, it seems to me that the low RPM oil pressure would allow the Accusump to bleed off pressure and might empty the cannister. This would leave the system unable to pressurize the oil passages in times of need. Is this incorrect? My first engine had extremely low pressure, 5 lbs at idle up to about 30 lbs maximum. My 1800 B motor makes 50 lbs at idle with hot oil.
MadMarx
Christian Marx
Germany
(51 posts)
01/02/2014 11:54AM
1977 Triumph IMSA TR8 Group 44 Canada Rover 4L
Re: Accusump
Posted by: MadMarx
Date: January 06, 2021 02:27AM
How about to take care about the pickup of the pump, rising the pump pressure, baffling of the oil pan?
That would help more.
Or switch over to a dry sump system as my car has.
60psi pressure at speed, 40psi at idle.
Edited 1 time(s). Last edit at 01/06/2021 02:29AM by MadMarx.
(5992 posts)
Re: Accusump
Date: January 06, 2021 12:10PM
An accusump can be helpful... provided you remember to open the valve. (and to close it before switching off the motor) This can be an automatic function, at least the first part can. But have you noticed that the 1/4 million mile engines in new cars don't need them? something to think about.
