ag1234
Arthur Gertz
(156 posts)
03/29/2023 08:26PM
Wanted 215 Olds Automatic flywheels
Posted by: ag1234
Date: October 06, 2024 09:06PM
Cheap please.
For the Greater Good, Art.
(4636 posts)
Re: Wanted 215 Olds Automatic flywheels
Date: October 07, 2024 10:38AM
Didn't Buick use the same part when they installed automatics?
(6569 posts)
Date: October 08, 2024 09:54AM
Art, I may have one.
ag1234
Arthur Gertz
(156 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: October 09, 2024 07:22PM
Curtis and all :Olds used cast flywheel. 215" Buick used sheet steel, for 5 element Dual Path torque convertor.
Onward, Art.
(4615 posts)
Date: October 09, 2024 08:28PM
Did not know that about the Olds. My Buick 215 flexplate that I no longer have was definitely not cast.
joe_padavano
Joseph Padavano
Northern Virginia
(160 posts)
02/15/2010 03:49PM
Posted by: joe_padavano
Date: October 09, 2024 10:16PM
The flywheel needs to match the trans, not the engine. The Buick two speed AT used a torque converter and a conventional flexplate. The Olds Rotohydramatic 5 used an internal fluid coupling. Without the rotational mass of a torque converter on the back of the crank, the Olds 215 needed a heavy flywheel, even with an AT. The AT flywheel has a spring-loaded damper plate that looks like the center of a clutch disc. The trans has what looks like an MT input shaft that fits into it. The bellhousing on the RH5 trans case is smaller as a result. If you put an RH5 behind a Buick motor, you need the Olds flywheel, and vice-versa for putting a Buick trans on the Olds motor.
(6569 posts)
Date: October 10, 2024 10:06AM
OK. I used to have 2 of those. Used them for feet on the leveling jacks on our old RV. Long gone.
ag1234
Arthur Gertz
(156 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: October 10, 2024 01:09PM
Take out the torsional hub and they're lighter than a steel, stick flywheel.
Art.
