3000bn7 Art McKinley Westport, MA (51 posts) Registered: 03/26/2024 10:05AM Main British Car: 1960 AH 3000 BN7 1967 Ford 289 |
Re: Intro new member BN7 with 289 project
The vertical grille looks better but the opening and trim for the original horizontal grille do not fit it properly, there a small gaps at each end. The obvious solution is to remove more bars and create the later factory rally look. We'll need to make the aluminum 'scoops' to finish it out. Our radiator is wider than stock, but we should be able to work things together OK.
