hirot Ian Hart Ashbourne UK (88 posts) Registered: 06/01/2011 05:15AM Main British Car: 1971 MGB GT (conversion) Rover 3947 R380 gearbox |
Car lift
Not really sure where to post this....but I am looking for a low lift (ie 2-3ft) car lift to get under my MG and there seems to be lots of choices in the States but few in the UK. I have found a Sealey 2.5 ton hydraulic lift, model AVR2500A, which looks like it might work.
Does anyone know if they are any good or can suggest an alternative that will fit in a small garage, isn't too expensive and won't remove my exhaust when I drive over it. Trolley jacks and axle stands are OK but hard work when you don't have much space. |
Re: Car lift
Ian, here's a couple of options................one from the USA and another from the UK. Something similar could be a DIY project for a person with a welder.
[www.youtube.com] [www.youtube.com] [www.carlift-ramp-mr1.com] |
Re: Car lift
Phil, both ramp/lifts look very good my problem is storing them, other than always put the car on them.
I was hoping for something I could drive over and leave on the garage floor. The Sealey one looks ideal if it works OK and doesn't remove the spoiler/exhaust. The ramps do at least look substantial. |
Re: Car lift
For folks with a lift like these, or with a 4-post lift, how convenient are they in practice? I had the opportunity to get a 4-post lift for cheap but decided to hold out for a 2 post to make suspension work easier. Now wondering whether there are operations that are easier on a 4-post.
Back on topic, did anyone get a picture of the 45° stand at the Skillman museum? If memory serves, it had a '60s Mustang GT250 or GT350 on it. I think if I needed a lift and had limited ceiling height, I'd build something that lifts like the linked ones above, but also tilts like that stand. |
Re: Car lift
The 4 post lifts usually have an accessory bridge that lets you jack one or both ends of the car up from the center (made in various configurations) so you can do suspension work. You should ask Pete Mantell what he thinks, as I believe he has both.
That tilt frame was pretty slick. But it would have to be easier to load/unload before I would be interested. Jim |
Re: Car lift
That's it. So, now imagine ramps like in the linked ones but also with the air bag tilt feature. If someone has limited ceiling height, I thi k it could ba a good option.
To Ian, could you recess the garage floor area where the lift is so it's flush when lowered? That would resolve the storage problem. |
Re: Car lift
I have some more pics of that lift I need to get off my phone.
Or just jack up one side really high & use bigger, stronger jack stands. ;) |
Re: Car lift
What a lift. Suspect its not available over here and not cheap. Like the idea of it being on wheels.
Rob, my original starting point was a pit, however, I leave near a river, the water table is high and you only have to dig down a little way before you hit water so it wasn't an option. So going down for a lift would get a little complicated without relaying the whole floor. |
Re: Car lift
Hadn't thought this one through. I guess I could rig the compressor up and get a jacussi.
Looked again at the sealey and it needs a tank with 200 litres I have only 50 so may be its back to long ramps. |
Re: Car lift
Looked again at Phils web addresses and found QuickJack Portable Lifts ( [www.quickjack.com] ), which look like they could easily fit in the garage and raise the car enough. Problem is not too sure how to position them to raise the car without removing a wheel which kind of defeats the object.
Any one used or seen them as I think I can get them in the UK. Edited 1 time(s). Last edit at 08/10/2015 07:06AM by hirot. |
Re: Car lift
Re: Car lift
Here's a suggestion for a DIY lift that could be done inexpensively: [www.clubcobra.com]
Mickey Richaud Mickey Richaud Townsend TN (198 posts) Registered: 08/25/2015 06:36AM Main British Car: '03 Jaguar XK8 Jaguar 4.2 |
Re: Car lift
X2 on the Kwik-Lift. I like mine.
Re: Car lift
Re: Car lift
I dunow. Them 2x4's are gettin pretty expensive these days.
Re: Car lift
Charles -
Looks good to me. 'Cept I'd be a bit concerned about termites. Then you're talking pressure treated, and those are REALLY 'spensive! |
Re: Car lift
Ian, a car friend has a car lift that uses a hand drill to raise and lower the car. I think he said "EZcarLift.com". When not in use he stand aganist the wall.
I am spoiled I have a 2 post lift, it has some pros and cons just as the 4 post lifts. |
Re: Car lift
That would be pretty handy, Charles. I think they would sell a lot more of them at a lower price point, though.
[ezcarlift.com] |
