barrysmgb
barry strugnell
(26 posts)
12/24/2010 12:57PM
x member cutting for pan
Posted by: barrysmgb
Date: March 29, 2011 09:34PM
i found a bronco oil pan and a ford van oil pan not a double hump pan 302 motor do i still need to notch x member thanks barry
Re: x member cutting for pan
Date: March 29, 2011 10:42PM
This pic may help -- that's a double hump pan & you can see it's the front hump that requires clearancing the cross member. If the bronco pan is the same depth @ the front, it'll need the cross member notch. If it's deeper it probably won't work (would require you to notch it too much). I can't imagine it's any shallower because that's where the oil pickup is.
