Re: headers with IFS-Does this look correct anyone??
I'll think you'll find that once the elbow/exhaust is routed and tucked under the chassis, that there will be no interference with any front suspension component.Trimming back the collector is a possibility depending on the elbow.
How about cutting the collector up a couple of inches and using two 45 degree exhaust elbows instead of a single 90* pipe...I'm sure there is a way to make it work.
That is probably what I'm going to have to do, use the 45s vice 90s. Separate question, where did you obtain the MG V8 decal/symbol from?
Quote: Made from scratch. The 'MG' is cut from the early radio blanking insignia, the 'V8' is the original badging for the MGB GTV8 and the 'Ford' badge is from a steering wheel/airbag module. |
Dave Kirkman is running a FastCars front suspension with Ted's RV8 style headers on his conversion.
[www.britishv8.org] Dave is currently in Colorado at BritishV8 2014 with his car. |
I have the Fast Cars IFS and I always thought those headers that went to the center were a little strange, however folks seem to make them work. As you can see in the first few photos of my build, I offset the collector toward the firewall. Definitely clears the suspension but I do get some frame contact and adds a little more heat to the firewall. So I guess what I'm saying is pick your poison.
[www.britishv8.org] |
Quote: Not quite that easy Rick - Dave, and a few others, use Coyote headers which are the originals developed by Steve Carrick before Ted took over and started to supply. Steve's collector location was a couple of inches further rearward - Ted's new design, like Michaels, allows full lock to lock wheel cut without tires hitting the collector.. |
All: Correct, Dave Kirkman is running this combo. Unfortunately, no photos of the actual area of concern. Ted did mention about the tires possibly rubbing, however, I only have 15" rims with 205-50-15, so fairly low profile of tire. I ended up ordering a different set from someone else. We shall see how these others work out.
Also, on mine I am running 225 40 R17 tires in the front. The wheels are 8 inch wide, and I cant remember the offset at this moment but thats a lot of tire to stuff in that area so you might want to consider your wheel tire combo before making the headers. I know for me back toward the firewall was the only place there was space for the collector given my tire and wheel sizes. I ended up cutting my headers up and re-making them to fit once I finalized my wheel choice.
I have Teds IFS, but like Dave, I have Steve's original header design. Looking at your pictures, are you sure simply shortening the collector isn't all that's needed? On mine, the 90 is tight to the frame rail - maybe an inch of clearance at most. The motor mounts Ted uses don't allow the motor to move much at all, so not a lot of clearance needed for the exhaust elbows. And since the A-arms pivot from that inboard point, they're not going to move much. I doubt you need more than 2 1/2" clearance to the lower A arm. But you can check by removing the shock and moving the suspension through its range.
Edited 1 time(s). Last edit at 08/03/2014 08:58AM by rficalora. |
