mgbazza
Barrie Egerton
Sydney Australia
(24 posts)
01/20/2009 07:40AM
1978 MGB GT Rover 3.5
Cold start problem
Posted by: mgbazza
Date: August 08, 2014 09:08PM
It 's winter down under & this one is very cold by our standards. At start up, I have to keep the revs up at 3000rpm otherwise the engine dies.I can keep it alive by pumping the gas pedal , but until the temp rises I can't get a steady tickover. once warm the tickover is 1000rpm in neutral.& the car runs very well. Any ideas ?
engine --- Range Rover 3.5
carb--------Edelbrock 500 manual choke
manifold--Buick 215
pump----- Carter
Rhds, Barrie E
robert1839
Tristan Cook
5579 Timber Ridge Dr, Mt Vernon, Skagit, Washingto
(118 posts)
05/06/2013 11:11PM
MGB GT 1972 Buick 215
Re: Cold start problem
Posted by: robert1839
Date: August 09, 2014 11:37PM
i had a simulare problem on my original MGB engine and for me the choke wasn't coming on all the way when i pulled the cable. so i would check that see if it is on all the way. try cupping you hands over the carb intake to simulate the coke being on and see if that helps, if it helps i say the coke isnt on all the way and if it dose nothing i am stumped.
302GT
Larry Shimp
(241 posts)
11/17/2007 01:13PM
Posted by: 302GT
Date: August 12, 2014 09:52PM
A low air cleaner can interfere with the choke.
mgbazza
Barrie Egerton
Sydney Australia
(24 posts)
01/20/2009 07:40AM
Posted by: mgbazza
Date: August 13, 2014 11:27PM
Larry, I had that problem once before. I cured it by using the top air filter plate from one maker & the bottom plate from another maker. Barrie E
(4514 posts)
Date: August 14, 2014 09:43AM
Hi Barrie.
Been wondering how you've been doin. The symptoms sound like a car with no choke at all. Like mine. I take it you have removed the air cleaner & verified that the choke plate is actually closing when you pull the cable?
mgbazza
Barrie Egerton
Sydney Australia
(24 posts)
01/20/2009 07:40AM
Posted by: mgbazza
Date: August 14, 2014 08:39PM
Good point Carl. I removed the choke plate last summer when it wasn't needed. I might have to replace it now with this cold winter we're having. Assuming I can still find it ! This is the first time I've used an Edelbrock carby. Holley carbs always seem to work better with the plate removed. We live & learn I guess. Rgds, Barrie
