Re: MGB Roadmaster
I think all the gages should be made to work. It almost seems ridiculous that we've had this problem for so long. It seems to me that the sender was changed. If it has not been, then there is a replacement still in the boot. But I think it may be a stock sender, and I doubt that would be much of an improvement. We may have changed that out the last time the car was here. Curtis donated the replacement.
Those gages may be just fine, I don't know. Nobody has ever been able to get them to work. But if we can put in a set of stock gages the gas would work at least. That is probably the most important one. A stock tach should work wired to one coil pack. And isn't it possible to hook up a regular speedometer cable to the T5? Is that the way yours is Carl? The rest are simple by comparison and can be picked up for at most $30 each just about anywhere. Ammeter, voltmeter, water temp, oil pressure, whatever. Black face, white numbers, and chrome bezel is just about the most common combination there is. Browse ebay. Pick 3. Buy a speedo cable. A weekend's effort and done. Jim |
Re: MGB Roadmaster
I think I have some spare 2" gauges from a TR4A, black face white numbers. Oil Pressure (mechanical), ammeter, probably fuel and water temp,
Re: MGB Roadmaster
My T-5 has a 90 degree box with speedo correction gears (still not correct) and cable to the stock speedometer. The electronic VSS in the Roadmaster T-5 is interchangeable with my mechanical speedo drive. The two units are interchangeable in Camaro T-5s.
Re: MGB Roadmaster
I have tach, speedo, fuel and temp, circa '71 mainly, with the rounded bezel, a few pieces with the angled bezel, also a rectangular oil gage and sender, not that we'd want that. They should be cleaned up but there should be enough of them to get a working set, with Dan's oil pressure gage though I'm not sure the bezels will all match.
I think that leaves the volt/ammeter. Where is that in the Roadmaster? We also have the spot where the air pressure gage is for the removed air suspension if we want to use it, maybe it could go there? I've forgotten if that's in the console or in an add-on mount. I'm not sure if it's even possible to over-rev that big block before the power falls off a cliff. Probably the least in need of a tach of any car in the fleet. I'd be happy to box up the lot of these gages and send them out, use 'em or lose 'em sort of a deal, they're just sitting in a box taking up space. Jim |
Re: MGB Roadmaster
From Hap Waldrop
Quote: |
Re: MGB Roadmaster
The Roadmaster will be going to Indianapolis this week (July 15-18) for BritishV8 2015.
PJ Lenihan will take over as its caretaker...the car will be going to North Carolina and will be campaigned on the East Coast. I've noticed telltale signs of a rear differential leak on the garage floor. I put the car up on the lift and check the level of lube in the diff. It required about five ounces to top it off. There is a whine in the differential...I used 85w140 Hypoid which seemed to quiet it somewhat. While the car was in the air, I greased the jerks on the rear suspension. The oil has not been changed on the car this year....but still looks clean and really does not have that many miles on it since the last change. As for funding....we currently have about $720 in the checking account at a local Champaign (IL) bank. We changed banks due to monthly fees being charge by the previous bank. We are NOT being charged fees at the current bank, nor are we receiving interest on the account. We will be "passing the hat" at BritishV8 2015 to bump the account somewhat. We will have insurance and licensing fees coming due which will eat about half of the account...should something catastrophic happen to the car, we would not be able to reimburse those who bankroll the repairs at this time. Related....kudos to those of you who stepped up to the plate with donations this year to the Roadmaster. It is much appreciated....and as the British American Deviant Automotive Sportscar Society is a Not-For-Profit, LLC...your donations are tax deductable. |
lawnvett PJ Lenihan Winston-Salem, NC (477 posts) Registered: 04/29/2009 11:37AM Main British Car: 74 MGB-GT 3.4 V-6 crate, 5 spd |
Re: MGB Roadmaster
Re: MGB Roadmaster
PJ, you making us drool!. thanks for your efforts. See you in May at Townsend
Re: MGB Roadmaster
the oil and filter where changed, rear tires to be replaced soon. I completed a few cleaning tasks Clay bar, polish, wax, carpet cleaned, seat covers cleaned and moisturized, glass cleaned.
I continue to show the car at many local events including a slide show presentation last week at a all European car club named Corsa Rosa. I continue to encourage young kids to sit in the car. I've picked up a few Moss Motors Challenge points during the just right Fall weather these last few weeks. And RM was on display in Hilton Head. Carl plans to drive over from TN to help me attend to a few issues: leaking heater valve, heater blower fan, interior lights, possible exhaust system rattle, water leaks into passenger footwells & spare tire area, gauges, etc. |
Re: MGB Roadmaster
Jim Watson and I have agreed to take the Roadmaster to the Street Rod show in Knoxville May 6, the V8 meet May 8-11, the local British/European car show May 13-14, and then to MG 2016 in June. We'll pick it up in NC, and hand it off in Louisville for the next leg.
We'll probably pick it up in late March or early April and tend to some of the needed maintainence. If that's agreeable to every one. |
Re: MGB Roadmaster
Re: MGB Roadmaster
Next RM work party tentatively 2-8-2016 in Jonesville, NC
all interested petrol heads invited to assist primary task to do: pull the dash and fix a few things like gauges, controls for heat/demist, map light, radio antenna, change the steering shaft for one with electric power steering, plan for future A/C, remove cooling system surge tank for mods by Jim Blackwood Lexington style BBQ provided wear appropriate garage attire start at 10 am finish no later than 7:00 pm Ya'll come PJ Lenihan aka Lawnvett aka: Roadmeister director of transportation BADASS |
Re: MGB Roadmaster
Let me know if you can come, I want to have enough food
I may tNOT o be able to reply btw JAN. 21-FEB2, 2016 as I will be in CUBA wifi and cellular not readily available for USA phones. Leave a message I'll get caught up when I return |
Re: MGB Roadmaster
Cuba was great
my photos are not organized yet, but some are on Facebook we are having a RM work party Monday Feb. 8, 2016 at 10;am 134 Bluff st Jonesville, NC ya'll come we will pull the dash and try to get some gauges working and defrost etc |
Re: MGB Roadmaster
looks like we've got a couple volunteers to attend the Roadmaster work day Monday 2-8-16; we will pick up where we left off last month fixing the little bits such as demister, fuel gauge etc.
I'm buying lunch so ya'll come, the bonus is to see Ken's excellent car collection. After a 3 week slumber while I was visiting Cuba, Roadmaster fired right up yesterday and attended a Triumph Club car club meeting last night. We spent 3 nights in Santa Clara, Cuba last week it was not a hectic or crowed like Santa Clara, CA. PS Just got the word that Alen Hendrix, Hendrix wire wheels Greensboro, NC is in ICU with internal bleeding after his Jeep was T-boned by a a speeding ner-do-well on Tuesday night. Edited 2 time(s). Last edit at 02/05/2016 08:43AM by lawnvett. |
Re: MGB Roadmaster
Not gonna work out for me this time, PJ. Sorry. I was looking forward to hearing about your Cuba trip.
If you want to put a 31" antenna behind the dash it will help with local strong stations. I would it slide in some clear tubing so it won't touch any metal & zip tie it loosely behind the dash crossbar. Edited 1 time(s). Last edit at 02/05/2016 03:20PM by MGBV8. |
Re: MGB Roadmaster
Another option for the antenna is to mount it on the A-post as shown in this thread on the MGE forum. I had mine mounted there before I took it up to Ted, and it worked very well yet wasn't obtrusive. I didn't mention this before because I didn't have a picture of it. I think they are still available.
[www.mgexp.com] |
Re: MGB Roadmaster
I gave Jim the chrome chinese Sanden I had used on my TR7 for almost one summer, until the engine blew. So, that is one step towards AC for the car. Have you sent him the surge tank yet?
