Re: MGB Roadmaster
Re: MGB Roadmaster
Nice work Jim, looks good and I noticed that it's an octagon to carry on the MG theme. I took the date from the first post you made about fitting a big block into a B on the MG experience bulletin board. [www.mgexperience.net] As is said, from that point on the rest is "history" and I'm both glad and a bit proud of having a small part in it.
B-Fast B-Strong William Smith (144 posts) Registered: 10/17/2009 11:28PM Main British Car: Bugeye Bodied Spriget |
Re: MGB Roadmaster
Re: MGB Roadmaster
Not bad Will, you want to take on that task?
JB |
Re: MGB Roadmaster
I wouldn't mind doing it , 4 pieces of sheet metal rolled on the end at the right length. Flair out at the bottom over a piece of heavy tubing to blend into the hood. put the four pieces together to form the box. Rounding the compound curves on the corners would be the hardest part but no harder than hand making a Chopper tank.
A piece of rubber seal around the sharp edge sticking up would be a nice touch and I think it would look factory rather than just a hole with the cleaner sticking up. Not that I don't like the Rat Rod look , but it looks like you are all doing some really elegant work on the Roadmaster and it would take it to the level it deserves. Will |
Re: MGB Roadmaster
It would have to be fiberglass Will, that's what the hood is made out of.
JB |
Re: MGB Roadmaster
Then it would be a lot more easy ! A little foam , a little Bondo make a mold , flip it over and make the part.
I know I make it sound easy , it does take some time to get the shape right, but then it is easy from there. I do think it would look good and give it a finished look ! Will |
Re: MGB Roadmaster
I don't think anybody else is going to do it, but if you want to work something up and bring it with you to the British V8 meet we'll sure take a look at it.
JB |
Re: MGB Roadmaster
I would need to do it on the car otherwise it would be impossible.
Re: MGB Roadmaster
Why is that? All you need is a stock hood to use as a buck and an outline of the air cleaner, couldn't you make just the bulge as a "preform" sort of like our fender flares? They will be bonded on just prior to paint, why couldn't the hood bulge be done the same way?
JB |
Re: MGB Roadmaster
How high does the air cleaner come up off the hood in the back and how high does it come up off the hood in the front ? If I had a an outline of the air cleaner and a few measurements I may could come close but it would never be spot on , it would look like a suit off the rack rather than tailored. I would want it to fit like a glove around the air cleaner so when I glue the rubber door seal on the top edge of it and the hood came down it would seal around it and even keep water out. I think a nice neat job would be in order . This thing would have function as well as look good. Maybe it would be neat to bring all the supplies and tools and put on a demonstration at the event on how to make a custom part !
Re: MGB Roadmaster
It would. Why don't you just plan on doing that?
JB |
Re: MGB Roadmaster
Re: MGB Roadmaster
I see what you mean Jim. I tried some other background colors but nothing popped in my eye. I think what you have will work, might change the color of the "Project Roadmaster" text to black or the gold/brown in the Buick logo and it would be less like Christmas with the green shirt. I like the car in red. Definitely a color to consider when choosing the final paint color. Either way, Steve can put me down for a couple of XXLs again.
Re: MGB Roadmaster
Remember the shirt is Forest Green. Let me know what you want changed.
Bill's idea the change the writing to black is good. Let here from you, I don't want shirts that will not sell. Steve |
Doc Hopalongfoot Marc Weitzman Huntingto Woods, MI (58 posts) Registered: 01/22/2008 11:45PM Main British Car: 1979 MGB roadster ford 302 |
Re: MGB Roadmaster
I like it. Need an XL.
Marc |
