jim jim begor brushton ny (31 posts) Registered: 12/30/2009 08:59PM Main British Car: 59 sprite gm 3.1 5 speed |
Re: leaf springs vs 4 link
It is a satchell 4 link it is working very well played pretty hard after going to the 10 bolt no problems do a search on satchell 4 link there is a lot of info on it some talk about noise with the rod ends but I dont get any road noise or clunking jim Edited 1 time(s). Last edit at 02/18/2011 08:17PM by jim. |
Any two angle links is a Satchell system.
To much angle on the links will transfer the loading to the side of the tubing. Tubing is not design to take side loads. Square tubing is. Weakest point on a welded rod link is the weld due to the steep angle of the link. The angle in which the tubes ares located is critical. To much angle will allowed the axle to move sideways due to flex of the tubing. The true original of Mr. Satchell system, had the links angle starting point form the center of the axle and to the outside. This was done for a better Roll Center for Racing ONLY. |
Bill from what I see of your work on line I respect your opinion that tube that broke was junk I miked where the threads were after
that broke I had very few thousands of an " after the trreads were cut I have 1" dom tube now .95 wall and no problems the car on the street handles very well I am very happy with it jim |
I am sure it works great Jim. I was not been a critic.
Actually the satchell link has all the tie in points at the furthest point out (closest to the tires) on the axle. The upper rods run pretty much straight in plan view and the lower rods angle to the center of the car at a 45 degree angle. A good discussion of it is here as mounted on a jaguar. [corner-carvers.com] its basically an upside down triangulated 4 link. It wont be an easy weekend swap out like a pre made bolt in kit though, thats for sure.
