cgill Chris Gill Salmon Arm, British Columbia (129 posts) Registered: 08/13/2009 12:06AM Main British Car: 1979 MGB roadster Buick 300 stroker with EFI |
Re: Engine Bay Trim
Thanks Gary. That coil holder is a work of art.
Maybe you should start producing small runs of your parts and give them to your good friends on this site! ;) |
Re: Engine Bay Trim
I just checked and it is the 5/8.
Well I am mulling over product. They have to be things I can make with quality yet make it worth while spending my time on. If there are not of quality there is no use trying to sell them. If they are not proffitable it only takes away form what we do otherwise in the laser shop. I would also have to be able to support the product. Some times I make a part for my car but I don't entirely know what model or year specifically the parts might fit. Here are some things I have been cutting to check fitment: Here is the coil on the deck: |
Re: Engine Bay Trim
Gary, Excellent work! You are going to have to do another thread on fine tuning the Holley 390. I am a little dissapointed though, I thought I had you convinced to do something a little more exotic. LOL. Hey, You could still mount that dual Rochester set up on the 4 barrel base later on!
Re: Engine Bay Trim
I really really thought about it but time is overtaking me. I have been totally redesigning the Pantera front to back. When I pulled this car apart I needed to get it back together and now it's been more then 6 months and I am still fiddling with it. My Ford 8n is blowing smoke and I need to re-build it this winter (mowing tractor). It's been waiting all summer to get the MG done.
It's was a decision made based on time. |
Re: Engine Bay Trim
Gary, your attention to detail is very impressive. I would love to have half of your fabrication skills!
Re: Engine Bay Trim
The fabrication skills are to be admired, but perhaps a better choice would be the Capital involved in the equipment? One could hire a considerable amount of work for the price of Gary's equipment. :)
Re: Engine Bay Trim
Well the capital in the equipment isn't to make hobby car parts; but it is a perk. And if I can make things which there is a need for; while I may never make a buck at it y comparison to the main jobs, it keeps me happy.
Re: Engine Bay Trim
Gary, That Tank is Amazing!
Now if we could have only started you at SFI instead of TBI you would still be FI and not carb. LOL! |
Re: Engine Bay Trim
I had it tuned preyty good under the TBI. I have absolutely no complaints about how it ran. Being a 64 with much of the 64 style, I like the minimum wire and carb combination.
I am also trying to do a better job with the front valance around the radiator. I will duct the intake through one side. I have cut some test pieces to get fitment. Waiting for a chance to get the updated panels cut on the laser: |
Re: Engine Bay Trim
Great work!! gary can ask a favor? can you let us view the car which is already done!
Re: Engine Bay Trim
I cleaned up the heater lines. They were just tubes floping through the bay and over the engine. I solderd connections to coper tubing, sand blasted and powdercoated the tubing black in high heat powder.
It's a much beter looking run to the servo water heater valve. I threw the other intake with short top hat, FI, distrib and other on ebay. |
Re: Engine Bay Trim
Angela, as if any car is ever really finished here's Garys MGB as it was at the Indy British V8 meet two years ago. [www.britishv8.org]
Re: Engine Bay Trim
I got the front shroud cut for the radiator but I am going to re-draw it and do it again. The openings have blank plates (not seen) which rivet/bolt in. The right side will be used to run the air intake through.
I wanted an O2 gauge but I didn't want it in view. I added a vacume gauge and put it behind the radio delete plate. It's hard to see in the photo but I used an ajustable bolt with magent on the end to hold the readio delete plate on: Edited 1 time(s). Last edit at 01/23/2012 09:20AM by burner1. |
Re: Engine Bay Trim
To me, engine bay trimming is the icing on the cake. I've seen brilliant power plant in some of these British cars but with poorly executed engine bay appeal. I love looking at the presentation of engine bays; it doesn't always have to be complicated as simplicity will always win hands down, however, with modern fuel injection, it's not always an easy task to simplify, it may be engineering substance over simplicity cleanness and appeal. I am faced with a challenging design myself Great work guys!
Cheers, Jacques |
Re: Engine Bay Trim
I tell ya I have great admiration for those who can make an injected system look clean; and there are some that do. Picking the system helps as well. Not every system can be adapted that well.
Re: Engine Bay Trim
The wiring is a real challenge, especially if sequential as each injector has it's own circuit. If you can make that look neat the plumbing isn't all that bad.
