Source for rear gear sets for 78 mgb?.............
I have a 1978 MGB that I dropped in a SBC with a 3speed manual. I kept the original rear axle and I really need to drop the rpms down at highway speed. Is there anywhere to find new ring and pinions in the 3.07:1 ratio or should I be looking for a used set? I hope I can change the gears without too much trouble, and I was wondering what other parts I would need to do this gear swap. Do these rears use a non-reusable "crush sleeve" ? Thanks for any and all info, this web site and the people contributing are brilliant!
Re: Source for rear gear sets for 78 mgb?.............
Most MGB owners would like a better ratio, but they are rare. For the cost of a new 3.07 ratio gear set, you can probably narrow a GM or Ford Dif. and have it suit you much better. old Saying ! "Rare as Hen's teeth"
Edited 1 time(s). Last edit at 11/06/2012 07:47PM by kstevusa. |
Where are you located?
I have an MGC diff (spline drive) available in a 3.7 ratio. MGCs were available in 3.07, 3.31, and 3.7 ratios. For my V8, I narrowed a Ford 8" and had an Auburn 3.27 posi installed. |
Jimmy, IMHO, bolt in a T5 and never look back. 5 speeds and several od. ratios. Good Luck, roverman.
There is a 3.07 on ebay right now (see link)
[www.ebay.com] Not sure where you are located but Babbit Bearing in Columbus, Ohio will take your mgb rear axle and machine @ 215 thousands off the carrier bearing..and install this CW&P...they have done many mgbs in this area including mine... |
Thanks very much fellas for all your input! I was afraid it wasn't easily available parts for resonable prices. An overdrive would likely make the most sense for my application but I may keep looking for a narrowed rear at the local swaps. I should buy the jeep dispatcher axle in the classifieds and be done. It really looks like the perfect width, I have wheels for that pattern, I may just talk myself into it,hehehehe, thanks again!!
You should jump right on that. It's a deal you won't be likely to see again.
Simon Austin Simon Austin Surrey, British Columbia (107 posts) Registered: 10/23/2007 01:44AM Main British Car: 1977 MGB V8 / 1970 MGB GT V8 project Rover 3.5 / Rover 3.5 |
JImmy:
You can also get CW & P from Targett Motorsport (banner ads here). He has the 3.07 for the Salisbury diff.... New gears. Max |
