Goto Page: 12Next
Current Page: 1 of 2
Robert J
Robert Janca
Oakland, CA
(53 posts)
10/21/2011 06:31PM
1975 MGB Ford 331 Stroker
Rear Rabbit Flares Installed
Posted by: Robert J
Date: January 26, 2013 09:49PM
Based on Keith Tanner's excellent photo outline linked below, I decided to go ahead and install some VW Rabbit fender flares on the rear of my '75 MGB. Thought I would post these pictures here to add to the database.
[forum.britishv8.org]
Re: Rear Rabbit Flares Installed
Date: January 27, 2013 11:45AM
Robert, I bought "new" Rabbit rear flares,not fenders, from Rock Auto. Approx $34./ea, plus shipping. Not an endorsement. Thanks for the pick's, roverman.
Date: January 27, 2013 12:44PM
Personally, I don't like 'em. Purely a matter of taste mind you and for those that do, that's fine. But it sort of puts me in mind of rubber bolt-on Jeep flares. Nothing in common with the rest of the body. But at least they are steel.
Date: January 27, 2013 10:16PM
Jim, they're very similar to Omni flares; do you not like those either? Maybe I'm biased, but I think they look very natural on the B.
Date: January 28, 2013 08:14AM
I don't mean to bash anyone's car or their craftsmanship. I know they have gained wide acceptance. I'm in the minority. It could be a minority of one. But the body contours of the MGB are all rounded. The only crease to be found anywhere on the car is the line down the side. It just doesn't meet my sense of aesthetics to put a crease around the wheel-well lip, that's all.
65elcmo
Steve Michaelson
(6 posts)
03/18/2011 08:29PM
Posted by: 65elcmo
Date: January 28, 2013 06:09PM
Thanks for the photos. I have this comming up. I see you slotted the inner sheet metal. Do you fold that up to the new flair? If so can you show some pics of that? Thanks, Steve
Robert J
Robert Janca
Oakland, CA
(53 posts)
10/21/2011 06:31PM
Posted by: Robert J
Date: January 28, 2013 10:08PM
Jim; No offense, but I always get a kick out of your mention of not liking the Rabbit flares. I feel that they are exponentially more tasteful than certain super wide rear ends. ;) They are very proportional to the car and look great in person.
In any case, I am using Omni flares on the front of my car and Rabbit flares on the rear. There is only a minimal difference between the two in person. Someone else built a GT with the same combination. I can post a picture if I find it.
Steve - I shortened the tabs a small amount (0 to 3/4") from the length they are in the picture posted above. I folded them to meet the inside of the flare, tack welded all of them to the flare, then fiberglassed over that. They are "under glass" now, so pictures will not be a possibility. Let me just assure you that it is very easy to do. The whole rear flare project was as intuitive as can be. Just take your time to trim and prepare everything properly. Preparation and patience will be rewarded.
Now on to the front flares...Wish me luck.
Robert J
Robert Janca
Oakland, CA
(53 posts)
10/21/2011 06:31PM
Posted by: Robert J
Date: January 28, 2013 10:14PM
So, this is not my photo and it is a repost of a repost; but this is supposedly a set of Rabbit flares on the rear and a set of Omni flares on the front. Not radically different.
Robert J
Robert Janca
Oakland, CA
(53 posts)
10/21/2011 06:31PM
Posted by: Robert J
Date: January 28, 2013 10:44PM
I'd like to point out one more interesting tidbit. You may notice that Kieth's flares sit up over the trim line on his car. The top of my flares just meet the trim line, like the flares on the red car shown above. I'm not sure exactly how Keith came up with that fit, but it looks like either way does work fine.
Ah yes - Buy a sheet metal nibbler. They are cheap on Ebay, they run on air and they make the most beautiful cuts you would ever like to make on any body metal. Seriously, buy one. Thank me later.
Date: January 29, 2013 08:39AM
Yes, those wide flares are sort of a necessary evil I guess. How else to avoid tubbing the car? I'll grant you it pushes the styling in the Ace/Cobra direction, which is not a result to be desired since the MGB is overall a much better car to start with. But how much rear tire is too much? IS there any such thing?
Of course it is all a system of compromises. The flares enable the wide tires. The wide tires enable the Jag IRS, and all three enable the 8" of suspension travel which has wonderful benefits for all aspects of driving. But could you see Rabbit flares covering the stock inner wheelwells moved outwards by adding a 3" strip of metal to the center seam? We looked at it, and I don't think it can be done. At least not without tubbing the rear and that is just a huge job once you're into the frame rails. The red car does look good.
Robert J
Robert Janca
Oakland, CA
(53 posts)
10/21/2011 06:31PM
Posted by: Robert J
Date: January 29, 2013 03:57PM
I'm just ribbing you Jim. I certainly don't know where you would put the wheels if you tubbed the car and anyway the rear end sets the stage for the blower through the hood.
Date: January 29, 2013 04:03PM
Actually you are quite right, since the flares came first. And of course it'd all be for nought without the wing;-)
NCtim
Tim Shumbera
Western North Carolina
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: January 29, 2013 06:17PM
If you were a glutton for punishment you could cut that lip off the flare or roll it softly under to meet the inner metal. It would be unique and keep with the softness of the MG's curves. Just a thought . . .
Tim
kerbau53
Geoff Morton
Naples, FL
(109 posts)
08/09/2010 10:27PM
78 MGB Ford 5L
Posted by: kerbau53
Date: January 29, 2013 06:43PM
Lip gone. Although these are Omnis not Rabbit flares.
65elcmo
Steve Michaelson
(6 posts)
03/18/2011 08:29PM
Posted by: 65elcmo
Date: January 29, 2013 07:56PM
Thanks Robert. Keep us informed on the fronts. Steve
djw090
David Witham
Warwick UK
(115 posts)
06/12/2008 11:20AM
MGB 1974 and MG ZT 160 turbo 2005
Posted by: djw090
Date: January 30, 2013 01:21PM
Geoff, that looks good. How did you do it? Just a bit of work with a body hammer perhaps?
kerbau53
Geoff Morton
Naples, FL
(109 posts)
08/09/2010 10:27PM
78 MGB Ford 5L
Posted by: kerbau53
Date: January 31, 2013 12:29AM
David,
Just hammer work and time. A fair bit of time.
Keith
Keith Tanner
Grand Junction, Colorado
(92 posts)
10/31/2008 01:45AM
For the purpose of this forum, 1972 MGB GT 5.7l Chevrolet LS1
Posted by: Keith
Date: March 08, 2013 05:53PM
I came up with my fit for functional reasons. I set up the suspension limits first, and at full compression that's where my wheel ended up. I needed to place my flares where I did to clear and cover the wheels. I do have a relatively wide track, chosen for the handling aspects.
I think they suit the car perfectly. I would argue that there are a number of angles on the car similar to the edge of the flares - especially on the GT. The front of the hood. The edges of the roof. The depression around the rear window glass. The top of the rear fenders. The headlight openings. Even the treatment of the Special Tuning air dam blends in really nicely to them. In person, the car doesn't look modified unless you realize that Pininfarina didn't put them there.
It's defintely not "cobraesque" - the Sebring flares are much further along that line.
Jim Stabe
Jim Stabe
San Diego, Ca
(829 posts)
02/28/2009 10:01AM
Posted by: Jim Stabe
Date: March 08, 2013 06:08PM
You guys are all wrong, you need to widen the whole car to cover the tires. Well, maybe just a little pooch out over the tire.
Robert J
Robert Janca
Oakland, CA
(53 posts)
10/21/2011 06:31PM
Posted by: Robert J
Date: March 08, 2013 08:00PM
Ahhh right, widen the car....Back to the drawing board.
That looks amazing Jim.
Goto Page: 12Next
