Bobs850 Robert Scott Custer SD USA (5 posts) Registered: 12/18/2017 09:46PM Main British Car: 1976 MGB GT V8 215 |
1976 Factory V8 Ignition Switch and Wiring
Looking to replace the original ignition switch . The car is a 1976 so it has the ignition lock. It has four wires. white / red
white / green white brown Looking for a part number on what I can replace this with. Thanks Bob |
Re: 1976 Factory V8 Ignition Switch and Wiring
Unless you need the key & Cylinder, get the first option # 263-691
Thanks
My Factory V8 is car number 2720 Must have been towards the end of production Many of the parts that are on the car do not match up with what should be there I have owned the car for quite a few years. Seems that what was left over from other models got thrown in 18G8905 is the switch that matched up Thanks for the input Bob |
