Triumph Sports Cars
Goto Page: Previous12345Next
Current Page: 2 of 5
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
1972 Triumph TR6 Ford 2300, 4 Cyl Turbo
Re: Reinventing my TR6
Posted by: tr6turbo
Date: August 22, 2010 04:45PM
Ken, At this point the biggest change will be a full chrome moly roll cage that extends forward to the spring towers.
There is a ton of work yet to go so I don't see making Townsend but who knows.
dale
74ls1tr6
Calvin Grannis
Elk Grove,CA
(765 posts)
11/10/2007 10:05AM
74 TR6/ 73 Spitfire / 71 MGB GT TR6/Ls1 Spitfire/stock 71 MGB GT/stock
Posted by: 74ls1tr6
Date: August 23, 2010 09:24AM
Have you seen Jim Prettyleafs half cage. I guess all you would need to do is the front part of the roll cage to finish it off. I rode in this car, it corner's like a flat pancake with no body roll at all.
Jim's link [www.britishv8.org]
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: August 23, 2010 05:38PM
I do like what he did but it does not meet the rules for drag racing.
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: September 05, 2010 10:43AM
Getting ready to weld the frame back together. I pulled strings to get the front suspension mounting points square and on center to the old section of the frame. One good thing about working with a TR6 frame is that from the fear axle center line to the front of the frame it is flat and all in one plane. That is why I have the frame up side down. I used a level to get everything level front to back, side to side and on the diagonals.
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: September 12, 2010 09:57AM
These are pictures of my TR6 + 2 fender. This fender is 2 inches longer then stock. I am lengthening the wheel base of the car 2 inches. The piece in front of the fender in the second picture is the 3 inch long piece I cut off. I then welded back on a 5 inch long piece from my wrecked fender. I also made a rust repair to the new fender using a piece from my old wrecked fender.
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: September 19, 2010 05:11PM
This weekend I got the engine, rear end and all suspension mounted back on the frame for a trial fit. I now need to make new front fuel lines and brake lines since the car is two inches longer.
Cypress, TX
(1726 posts)
Date: September 19, 2010 09:25PM
Great progress Dale.
alana
alan atkinson
10567
(217 posts)
06/19/2008 08:06PM
68 TR250 LS2
Posted by: alana
Date: September 20, 2010 06:02AM
Can I ask why 2" longer? It seems like a ton of work for what superficially seems like a very small wheelbase change.
74ls1tr6
Calvin Grannis
Elk Grove,CA
(765 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: September 20, 2010 11:04AM
My guess for 2" longer would be for the strip.
alana
alan atkinson
10567
(217 posts)
06/19/2008 08:06PM
68 TR250 LS2
Posted by: alana
Date: September 20, 2010 12:07PM
Well yes, I'd guessed that ;)
My question was more along the lines of "Since it's so much work, why go with ONLY two inches".
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: September 20, 2010 04:48PM
The two inches is required to meet the 90 inch min requirement for drag racing.
(1527 posts)
79 MGB, Buick 215
Date: September 20, 2010 05:16PM
Since you're going to all that trouble for two inches, ya might as well make it two inches wider on each side, too! ;)
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: September 20, 2010 08:12PM
Carl, There is alimit as to how much abuse I want to put myself through. The rules require a minimum wheel base of 90 inches. I was called on it once. Making the car 2 inches wider gives you more frontal area which would slow you down. The other reason for doing it is the challenge and being able to say I did it. It will be an even more unique car then it was.
(1527 posts)
79 MGB, Buick 215
Date: September 20, 2010 08:27PM
Frontal area? Okay, just widen the track width & add flares. Straight line action is a blast, but that is just the in between" stuff. I'm just trying to look out for you & The Dragon that beckons. :)
alana
alan atkinson
10567
(217 posts)
06/19/2008 08:06PM
68 TR250 LS2
Posted by: alana
Date: September 20, 2010 08:49PM
You've all seen Len Renkenberger's car, right? He put about 11" and a back seat in it back in the 80s so he could drive the kids around...
http://6-pack.org/j15/images/phocagallery/trials/2007Trials/thumbs/phoca_thumb_l_IMG_1536.JPG
http://6-pack.org/j15/images/phocagallery/trials/2007Trials/thumbs/phoca_thumb_l_IMG_1534.JPG
http://6-pack.org/j15/images/phocagallery/trials/2007Trials/thumbs/phoca_thumb_l_IMG_1535.JPG
These images are from the 2007 TRials in Hershey.
Edited 2 time(s). Last edit at 09/20/2010 08:55PM by alana.
(1527 posts)
79 MGB, Buick 215
Date: September 21, 2010 11:20PM
Very sharp. I like it!
(1527 posts)
79 MGB, Buick 215
Date: October 03, 2010 08:55PM
How goes it, Dale?
tr6turbo
Dale Knapke
Sidney, Ohio
(131 posts)
08/24/2008 09:44PM
Posted by: tr6turbo
Date: October 04, 2010 07:43PM
Its ready to go to the race car shop to have the roll cage installed. It will be getting a 10 point cage. Four for the basic cage, two side bars for side impact, two going back behind the rear axle and two going forward to the front suppension cross member. What do you think if I let the fenders off and make a Rat Rod out of it?
74ls1tr6
Calvin Grannis
Elk Grove,CA
(765 posts)
11/10/2007 10:05AM
Posted by: 74ls1tr6
Date: October 04, 2010 08:29PM
"Wow"
Dale you have not wasted any time! I'm impressed at how fast and resourceful you are Dale!
"Awesome" Rat ummmm, I vote for fenders.
(1527 posts)
79 MGB, Buick 215
Date: October 04, 2010 10:45PM
"What do you think if I let the fenders off and make a Rat Rod out of it? "
Yeah, big block Chevy with a blower.....it'd be awesome! :)
