Triumph Sports Cars
Goto Page: Previous12345
Current Page: 5 of 5
Maņana
Steve Wten
Toronto Canada
(18 posts)
02/28/2015 01:35AM
1978 Triumph Spitfire 1991 Miata 1.6
Re: Miata 1.6 into a 78 Spitfire
Posted by: Maņana
Date: June 06, 2018 01:33PM
Joe, this looks really cool.
Sorry to hear about the rust, but really like the way you're thinking with the suspension.
That's similar to my train of thought, and of course there have been many before us with the same starting point.
At first I thought that the plates you mount the diff to might not be enough, however, they're really not bearing any vehicle weight, just the diff, so should be good.
Wishbones look like good geometry, I'm thinking to somehow get the coilover mount inside the lower A-arm. I know lots of cars have them outside, but it's a goofy hang-up of mine.
Did you have to cut up the tub at all to fit in the second row of rear lateral framing?
Really nice to see this. (thumbs up emoticon!)
joebarry10
barry davis
(23 posts)
01/16/2016 09:39AM
Posted by: joebarry10
Date: June 06, 2018 02:49PM
Thanks Steve. Means a lot coming from you considering I have been studying your website and copying as best I could - your site made the transition to the 63 much easier - that's absolutely true. Yes, unfortunately it did require cutting into the cabin area but not as much as I first thought - but still hated doing it. Due to the placement of the springs, I had to cut just into the base of the rear deck by about an half inch. Springs could have probably fit on the inside of the lateral framework with professionally designed A arms. Honestly, I just went with what I thought I could do safely and with least cost.
Maņana
Steve Wten
Toronto Canada
(18 posts)
02/28/2015 01:35AM
Posted by: Maņana
Date: June 06, 2018 03:41PM
I figured you may have had to, but it definitely looks close.
I've been thinking about cutting a swath out of that area, specifically the vertical part and moving it forward; of course I think that that part contributes much to strength so hopefully I could recreate that strength further forward. That would reduce the area available behind the seat, but make more room for the suspension. Could even cut a bit more out front and then weld that in below the gas tank, or just fab something similar. Just thinking out loud.
But if you just cut a bit off the corners and managed to sneak that new frame assembly in, that is simpler and likely stronger than I could do.
Keep it up Joe, looking forward to whatever you're willing to share.
joebarry10
barry davis
(23 posts)
01/16/2016 09:39AM
Date: March 15, 2019 06:01PM
Need some wiring help!! PLEASE!! Running, moving, stops @ but this wiring!! GEEZ!!! How can I identify which wires I can delete AND fan wiring. Trying to attach photos if I can get them smaller.
joebarry10
barry davis
(23 posts)
01/16/2016 09:39AM
Date: March 15, 2019 06:13PM
joebarry10
barry davis
(23 posts)
01/16/2016 09:39AM
Date: March 15, 2019 06:17PM
joebarry10
barry davis
(23 posts)
01/16/2016 09:39AM
Date: March 15, 2019 06:18PM
joebarry10
barry davis
(23 posts)
01/16/2016 09:39AM
Date: March 15, 2019 06:19PM
joebarry10
barry davis
(23 posts)
01/16/2016 09:39AM
Date: March 15, 2019 06:24PM
Maņana
Steve Wten
Toronto Canada
(18 posts)
02/28/2015 01:35AM
Posted by: Maņana
Date: March 21, 2019 05:34PM
Hey Joe,
This is what I put together for mine...
Can be found here as well....
[stevew10.wixsite.com]
mbyrne
Michael Byrne
(1 posts)
03/26/2019 11:59AM
Posted by: mbyrne
Date: March 28, 2019 10:18AM
Hey all. Does anyone know how to get in touch with Doug? I'm actually thinking about picking up the miata spitfire he built, and I wanted to speak to him about it and other pitfalls he happened to come across, and possibly purchase his notes and diagrams from him incase something went wrong, so I'd have a place to start. If anyone has his contact information, I'd greatly appreciate it. It seems like he hasn't been active here in a long time.
Thanks!
