100-6 Toyota Swap
Hi, New to the forum, but have had Big Healeys in the distant past. (30 years ago). Currently I have Triumph Spits and Heralds.
I've recently acquired a 1957 100-6 with a decent frame and panels. I want to do an engine swap and before I get too far into it, I'd like some feedback. My thought process is to use a Toyota BEAMS engine and 6 speed trans. 2.0l, 4 cyl. 200hp stock, 162 ft-bs torque. Non-turbo. This is a JDM engine used in the Japanese version of the IS300, called an Altezza. The Altezza used a 4.11 rear diff and would mate up nicely with my original 4.10 diff (overdrive rearend). Exhaust is on the same side as the Healey 6 cyl and could be adapted to the original Healey muffler. This engine is commonly used with drifting. The engine/trans is about 10" shorter than the Healey combo and would sit back further in the engine bay for better weight dist. The car has wire wheels, but I want to switch to steel or mags. Will need advise on changing front spindles. I looked into Mustang II suspension and it is too wide. I've also considered putting an electric steering motor in line with the steering column from a Toyota Corolla. Got this tip from a local hot rodder. Not trying to make a drift car, just want reliability and highway cruising speed with decent suspension. It would be lighter and have decent power without twisting the frame up. Thoughts???? |
Re: 100-6 Toyota Swap
I think you engine choice is spot on.
A lot of people in the past would stuff v8"s into these cars. Nothing wrong on going that route. Being that these cars came with four cylinder engines it seems to be an appropriate choice. Where will you get this engine being that it is quite popular with the tuning /drifting crowd? Cheers Bwa |
The Toyota 3SGE BEAMS engine is readily available in the US through many JDM importers.
I've been looking for the "right" one on-line. Mileage, condition, sensors etc. |
