Goto Page: 123Next
Current Page: 1 of 3
(2465 posts)
Ford style girdle
Date: December 19, 2009 01:35PM
The Ford style girdle fits inside the pan and just ties the main caps together. Would be easy to make for a Buick/Olds 215,300,340 or early Rover.Of course it would'nt need the oil pump kick out and would be straight like the other end.Here is a picture:
Edited 4 time(s). Last edit at 12/19/2009 05:11PM by mgb260.
(2465 posts)
Re: Ford style girdle
Date: December 19, 2009 02:55PM
Another pic:
Date: December 19, 2009 04:39PM
Jim and clan, thats great for a sbf. Why do we "need" this for a 4.0/4.6L? 215 and 300, maybe, after-all , Repco used it, for formula 1. We've heard reports of late Rovers with stock crank and rods, living with a 400 hp. squirt of NO2. How many horses we tryin to control here? roverman.
(2465 posts)
Date: December 19, 2009 05:05PM
I was thinking only 215 and 3.5 and 3.9 Rover.Oh, and 300 and 340 like Jim Blackwoods. 4.0 and 4.6 have crossbolted mains so are fine.Edited earlier post.
Edited 3 time(s). Last edit at 12/19/2009 05:12PM by mgb260.
WedgeWorks1
Mike Perkins
Ellicott City, Maryland
(460 posts)
07/06/2008 08:07AM
Posted by: WedgeWorks1
Date: December 19, 2009 05:19PM
I see this working for an engine that has tall bearing caps that are above the oil pan mounting flange which is better than nothing. The rovers with 2 main bolts for competition use a gridle that goes between the pan and the block with the caps incorporated. The rover 4 bolt mains really doe not need a girlde. I can see it used for high rpms. Here is something Im going to try on my next engine build (high rpms hint..hint....)
(2465 posts)
Date: December 19, 2009 05:31PM
Cool Mike! That will add some ridgidity ( don't know if that is a word or not) to your monster bores.
Edited 1 time(s). Last edit at 12/19/2009 05:39PM by mgb260.
Date: December 19, 2009 06:18PM
Thanks for the "pic", Mike. I hope your not giving too much away? lol. May want to consider having the tops of main caps,(as in your ONE spy photo), fit up into a "register/counter groove" in underside of girdle. U-no for an undisclosed amount of rpm, hp, fuel, boost and anything else you can hide from us ? roverman,"tells-all".
pcmenten
Paul Menten
(242 posts)
10/08/2009 10:40AM
Posted by: pcmenten
Date: December 19, 2009 07:46PM
I think I'd buy one for my Olds if it were available.
It would be useful on a Buick and Olds 215, and on the Rover 3.5, 3.9 and 4.2.
The 'Power Tuning' book talks about the problem with main cap fretting. This girdle would help with that. And, a fella could put some crank scrapers on it.
WedgeWorks1
Mike Perkins
(460 posts)
07/06/2008 08:07AM
Date: December 19, 2009 08:27PM
We will see how the caps look at the area of the girdle and go from there. I am sure on the final product it will be contours with the caps for a nice tight fit along with the area around the caps. We are even thinking about a tab that will go between the block and the cap for the side bolts on the bearing cap to really lock this thing in. Some maching of the cap and the block for a zero tolerance fit.
Date: December 19, 2009 09:15PM
Mike, back in 83' I made billet caps from 7075 T6. No problem with expansion.With billet caps they could protrude up-into girdle-counter slots.No way to "dance" or "don't fret-it". I'm telling-all-Mike. roverman.
Date: December 20, 2009 12:49AM
Mike, did you use a cad/cam file to mill and drill that girdle? I need to make a 1/4" thick pan spacer and I figure I'll just run the extensions over to the main cap studs and stop there rather than crossing the caps. That'll tie the caps to the pan rail which should work quite well. But I'd just as soon not have to do the layout if it's already been done. There are a few guys on the Buick list who're also interested.
Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Posted by: Wotland
Date: December 20, 2009 05:43AM
Other pics of the girdle plate :
http://i44.servimg.com/u/f44/11/14/83/96/culass10.jpg
http://i23.servimg.com/u/f23/11/14/83/96/culass11.jpg
http://i44.servimg.com/u/f44/11/14/83/96/culass13.jpg
http://i44.servimg.com/u/f44/11/14/83/96/culass15.jpg
WedgeWorks1
Mike Perkins
(460 posts)
07/06/2008 08:07AM
Date: December 20, 2009 07:42AM
Wotland-I knew you had more pictures. I have one that was just cut and will get on here.
Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Posted by: Wotland
Date: December 20, 2009 07:58AM
I made 3 girdle plates, studs waren an special order to J.Eales in UK to use the maximum thread lenght in the block.
Edited 1 time(s). Last edit at 12/20/2009 07:59AM by Wotland.
Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Posted by: Wotland
Date: December 20, 2009 08:11AM
Th best girdle plate I ever seen is this one made by Motorpreps (NZ) :
http://i34.servimg.com/u/f34/11/14/83/96/p76lad10.jpg
Of couse this time you need of custom main caps.
I had also this one which is cast and not machined :
http://i14.servimg.com/u/f14/11/14/83/96/girdle10.jpg
http://i14.servimg.com/u/f14/11/14/83/96/girdle11.jpg
Date: December 20, 2009 11:55AM
Girdle Guys, If using .25" steel, laser is most economical way to produce low quantities,(non-stamped). NOT plasma cut ! Aluminum girdles, .75"- up, water-jet is best. I have (2) CNC. mill's and I would pay for water-jet or laser.If I wanted to "nest" the main caps into the girdle, thats precision machining. roverman.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Posted by: NixVegaGT
Date: December 20, 2009 01:07PM
Does the mains' fastener surface line up with the bottom of the block? This girdle looks like it just has clearance for the top of th main caps. OR is there some spacers to mate up to the fastener surface. Maybe this wouldn't matter if the studs were held secure by the girdle. Is that what's happening here?
Date: December 20, 2009 07:58PM
We had a big discussion about this over on V8Buick, most guys wanted to machine the caps apparently but how do you hold them in the block to do that? (and if they aren't machined in place they will never be exactly right) Plus, unless you align bore the block after the caps are cut and the girdle is fitted nothing is going to fit exactly right anyway. Some liked the clearanced girdle. I think a 1/4" steel plate that bridges from the pan rails to the main studs is going to be as good as you need. Unless maybe you're building an F1 engine. Water jet cut, CR steel, none of this fancy blanchard grinding etc. No need to spend megabucks on it.
Date: December 20, 2009 11:01PM
Jim, First question. Is 350 sbb " Y" skirted like its predecsssors? Whats the plan for evenly preloading each cap in a vertical plane. Will your un-ground plate be flat enough to evenly pre-load caps. FWIW. laser-cut should be less expensive than water-jet with no measurable distortion. Good Luck, roverman.
Date: December 21, 2009 12:16AM
Yeah, the blocks are very similar except for being iron instead of aluminum. Some differences in oil passages, some differences in water ports, and of course the deck height, main journal and bore size. That's about it. You have to shim between the girdle and spotface on the main caps no matter what you do unless you cut down the pan rail by a significant amount or replace the main caps with custom made ones, and the commonly agreed best practice is to shim a few thousandths proud, say .003-.005 depending on your girdle thickness and condition of the pan rail. So right there you're throwing away that expensive blanchard grinding job. No point in it. CR is typically flat to less than .001 anyway and if you grind it you warp it so what's the point? The CR is already going to be as flat as the pan rails. That's not your precision mating surface anyway, it's just a clamp and a stabilizer.
Goto Page: 123Next
