Re: Ford style girdle
Thanks, Jim. That's what I was looking for. Thanks for framing my question better, Art.
So who was it that figured out that the supercharged Buick v-6 caps are beefier and larger than standard Rover? That might be the ticket for the girdle..
Tony, Ever try to retrofit main caps from another motor? They don't line-up. Back in 62'. Jet Fires had beefier caps and longer,12 point bolts, Pistons with thick domes. Billet steel caps are easy to water-jet and then light finish machining. Normal line-bore and your done. roverman.
Sure Art..
I put splayed caps on my old chevy 400 block.. No big deal really.. The stock supercharged v-6 caps would take some machine work but so would billet caps.. Mill, line bore, hone, etc.... We are just talking using the girdle for the older non-crossbolted blocks... Right? In guessing crossbolted caps add a new dimension retrofitting.. any thoughts? Art ....do you think you could make the big caps for a decent price? Id imagine the Supercharged v-6 caps are not really plentiful yet.. Damn where did I see that post????? |
Tony, "Mike" of Wedgeworks was showing alum. girdle for a cross bolted block. I believe the issue was how to address the fit with stock caps. I will need a dimensioned dwg., material choice and quantity, to make a sensible bid. We know that #1020 steel, from the mill, has a higher yield strength than "chrome moly" in mill state ,right? roverman.
Ahem.... If you want a set of Buick Supercharged V6 maincaps to play with... go here...
[www.moradpartscompany.com] Just ask.. Greg |
Greg, that "is" an impressive looking cap. Even beefier than a Jet Fire. In 215 engines, I always had, off-set problems between motors. What's your plan for nesting in a girdle? You don't like cross bolted mains? Good Luck, roverman.
Can we just"focus" heere? Someone got dwg.? Quantity? Reason why one would'nt use nut/spacer,under girdle? More rigidity?(word).roverman.
Even those V6 caps need a shim between the spotface for the nut and the girdle. That spacer has to be custom fit to each side of each cap with (traditionally) .002" to .005" of interference so that the girdle actually does help clamp the main cap to the block rather than just stabilizing the loose end of the stud. Then there is the clearance over the middle. You either have to cut the cap (which I think in general is a bad idea but don't seem to get much agreement on) or you have to cut the girdle, or both. But if you use the interference fit to the spot faces then the girdle will bow where it goes across the center and contact, therefore support will be lost. Even if you use a zero clearance fit it's less than ideal. Think of a multi-leaf car spring, it's much less rigid than a solid block the same size. Best might be to cut the parts for a zero clearance fit and furnace braze them together assembled to the block. But an aluminum block will melt before the brass so that would be a problem too. My conclusion was that there is no easy way to win this one, and with anything less than an all out effort (custom casting for girdle and caps in one piece, etc) all you are accomplishing is to stabilize the loose ends of the studs and a 1/4" CR steel plate that only extends in to the studs will do that just fine. Add that to a cross bolted block and it should be good for anything but an all out maximum horsepower and rpm dry sump race engine, or maybe the Rotus Brossum. For that maybe you need the one piece sump/cap unit. Pricey even if you can find one.
I might have a simplistic veiw on this? 2-3" od. mic's and a counter bore, large enough on od. and correct fitting pilot. A good drill press/mill and semi-skilled user. Spot face the nut/washer area of all caps till the're good enough.Use 0-1" mic's to make all ten of your nut washer combos the same thickness(just enough to clear the cap). Install girdle with ten more nuts on top. I think we're done? Update, "Rotus" not need girdle on bottom, has two on top(heads). Maybe with blower, billet caps"nested" into billet girdle, hold "boocoo" power. roverman.
Edited 2 time(s). Last edit at 12/29/2009 02:38PM by roverman. |
Not done. Interference with cap at center.
OK, I think my next question is, how much needs to come off top of caps to get girdle to .003-.005" above pan rail? I suppose this will vary with specific series, ie. 215-350"? Silicone sealer at final assem.? All studs on the pan rail with (4) 5/16"? I was thinking, shoulder studs for use on alum. blocks,(softer metal/better support) Once I get a dwg. and a qty, I can get them quoted.roverman.
Re: Ford style girdle/Rover-Buick
Ok, I'm ready to build (10) girdles. Perhaps (5) Rover and (5) 340/350 Buick. I need a drawing for 340/350. Material will be A36 or 4130. Depending on how serious the response, ie. not like the (10) roller cam blanks, I had made. I feel the cross bolted Rover will need this with the potential of TA heads. Anybody ? Thanks, roverman.
