motek George Smathers Spokane, WA (118 posts) Registered: 09/12/2009 02:45PM Main British Car: 1967 Morris Minor (48 hp @ crank!), 1971 TR6 302 |
Is this driveline angle OK?
Re: Is this driveline angle OK?
I think I am OK in the vertical axis, but I am worried that the differential sits too far to the right (when viewed from above).
Mine looks the same as yours George. I don't think you want it dead on anyway. U-joints need to work a little!
Thanks Rick and Calvin. If it's good enough for Calvin then I'll be sleeping easier tonight.
George |
As long as the angle between the centerline of the trans and differential pinion are parallel in both the vertical and horizontal axis any minor offset won't be a problem, in fact it's actually better to some extent for the life of the needle bearings in the u-joints. The booklet you can download from this link will explain it very well. [www.iedls.com]
