Re: Edelbrock Carb issues....
OK, but isn't this set up 15 yrs old in this car? What then would cause points to burn up between Jan 7th and 11th? Seems like Chris needs to figure that out or he might have problems with the electronic conversion too.
mtnrek@yahoo.com Chris Buckaloo Jacksonville, fl (67 posts) Registered: 02/06/2009 12:33PM Main British Car: 1962 Austin Healey 3000 BT7 Ford 289 Smallblock V8 |
Nice, thnx again guys.
that Pertronix looks great. Question tho, Can you install the Ignitor III into a stock distributor? it wasn't very clear on the site. |
oh... Rob, I didnt' have a balast resistor on it. a feel the points gap may have been a little to much. So i think it was user error on the melting of the new points. but i want to go to the electric conversion so i don't have to worrie about that anymore.
Had her all set up for the parts replacement last weekend....
Replaced the points with the Pertronix as suggested... Dayum!!!!! She's a hoss!!! Now i wish i had started on the wheels and brakes first! She runs absolutely beautifully! Illbget some video this weekend and post it. I cant thank u guys enough! |
No more Carb Issues! Or ignition issues for that matter.
Here's a linky for yur viewing pleasure. [www.youtube.com] |
not bad for hipo exhaust manifolds without any exhaust!
The whining noise you hear is the timing "gear" set. We'll see how well they hold up... I've since painted the engine bay, working on the firewall, and will be replacing the brake lines here soon. know where i can get a 5 way union for the brake line system? |
Is your brake master a single circuit? If so you may want to consider swapping for a dual circuit master. That way if a line gets compromised you likely have enough braking left to get you stopped. Side benefit is you only need a couple of T's then too and they're easy to find.
i'll def look into that, thnx for the heads up
