MG wanna B
edward davidson
mount olive,n.c.
(96 posts)
11/20/2013 07:47PM
1977 mgb 2.8 l gm v6
selecting a T5 transmission
Posted by: MG wanna B
Date: December 30, 2013 08:42PM
I ran across a Borg-Warner T5 5sp from an 89 v6 Camaro. I have sent a message to try to find out the mileage on it, as well as any other information I can get. their asking price is $250. I have asked for their best cash price for it, and it's about 1 1/2 hours away from me. it looks like it is in pretty good shape, and doesn't have the bell housing, nor any of the clutch parts. just the tranny, and shifter.
is it worth the money, or, should I run the other way?
thanks
(moderator replaced title to make it more descriptive...)
Edited 1 time(s). Last edit at 12/31/2013 11:59AM by Moderator.
(2465 posts)
Re: NEED ADVISE
Date: December 30, 2013 08:50PM
Ed, The V8 T5 has better ratios for the stock rear. If you get D&D's narrowed S-10 rear with low 3's ratio the V6 gears are fine.
MG wanna B
edward davidson
mount olive,n.c.
(96 posts)
11/20/2013 07:47PM
Re: NEED ADVISE
Date: December 30, 2013 08:57PM
thanks. are there gears that can be put in the stock rear end? I have been talking with mark about a complete kit for 1 of 2 possible cars I want to do. I have a 77 and a 76, but the 76 would be the car that I'm gonna be doing, as it is in the best shape. I hate to, but, it is surely headed that way. the 77 is just parts, complete, but just parts.
(2465 posts)
Re: NEED ADVISE
Date: December 30, 2013 09:11PM
There are 3.07 and 3.31 MGC gears(carrier needs machined or use MGC carrier). I think Robert Kirk found some aftermarket 3.07's that bolt up to the MGB carrier. Do a search on Mgexperience site for the thread. Usually used go for around $500, more for new. I think D&D's narrowed S10 was around $1500.
MG wanna B
edward davidson
mount olive,n.c.
(96 posts)
11/20/2013 07:47PM
Re: NEED ADVISE
Date: December 30, 2013 09:24PM
here's some pictures
(2465 posts)
Re: NEED ADVISE
Date: December 30, 2013 10:05PM
Ed, The main thing with the T5 is there are no stop bolts for the shifter, an aftermarket shifter fixes that. You should shim the front bearing up to .001 end play and use quality lube. I like GM Synchromesh. I know you want D&D to do a kit for you with a 215 or 3.5 Rover but, think about it and later you will want to upgrade to something bigger. I'd go at least 4.0, maybe 4.6 Rover. I've had a few 215's and they are cool little motors but I've had 3.4 and 3.8 V6's also and they are about the same power. Just something to think about, the engine pretty much looks the same.
MG wanna B
edward davidson
mount olive,n.c.
(96 posts)
11/20/2013 07:47PM
Re: NEED ADVISE
Date: December 31, 2013 07:34AM
thanks,
i'l keep that in mind.
what if I did a 302, with a mustang 5.0 T5. I'm finding them locally, too.
my big thing is that I don't want to cut the fender wells.
denvermgb
Brad Carson
Aurora, Colorado
(104 posts)
03/10/2008 12:45AM
1975 MGB 350 SBC bored 0.040 over
Re: selecting a T5 transmission
Posted by: denvermgb
Date: December 31, 2013 01:09PM
I found the Mustang V8 T5's much more plentiful than the GM V8 T5's. Also, it looks like the metal tag has been removed that identifies the specific model/year of car your tranny was in. I believe the number starts with a 1352... Good luck with your search.
Brad
MG wanna B
edward davidson
mount olive,n.c.
(96 posts)
11/20/2013 07:47PM
Date: December 31, 2013 06:20PM
you're right, it is a 1352 197, which is a v6 "WC" tranny. I have the price down, and he is throwing in a bell housing. I still plan to get it, but will most likely resell it. had to wait, due to batteries dying in 2 trucks today, and new car trailer tires, so it will have to wait a bit.
