minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Any update on TA Rover heads ?
Posted by: minorv8
Date: July 28, 2014 05:00AM
Has anyone done anything with the TA heads, Art, Dan J. ?
Itīs been really quiet lately, would be nice to hear something solid about the heads.
Re: Any update on TA Rover heads ?
Date: July 28, 2014 11:23AM
Hi Jukka, Good to hear from you ! Dan Jones and I, each have a set. I don't know his state of developement, for them. I'm pretty buried with putting Lotus 907 heads, on the RV8, including machining a Ford Windsor , raw forging crankshaft, to fit. Fred Key, is close to finishing, with his 907/Lo-ver ? Cheers, roverman.
Dan Jones
Dan Jones
St. Louis, Missouri
(280 posts)
07/21/2008 03:32PM
Posted by: Dan Jones
Date: July 28, 2014 01:40PM
Jukka,
I'm just now finishing up another project and plan to send the TA Performance Rover heads out for porting in the next few weeks. Then I need to see what it will take to get the Rover on the dyno. I've got one down at the shop I use (100 miles away), along with some headers and bellhousing, etc. but still need some other bits to get it running on the pump.
Dan Jones
Date: July 28, 2014 01:57PM
Dan, Do you want a "roller" cam, to try out ? Your results may vary. Cheers, roverman.
Dan Jones
Dan Jones
St. Louis, Missouri
(280 posts)
07/21/2008 03:32PM
Date: July 28, 2014 06:50PM
Solid or hydraulic? What are the specs?
Dan
Date: July 29, 2014 11:19AM
I "think" I have (2),the orig. Huffaker and one "corrected" by Steve Smith Cams,(originally built by Howards Cams,consumed 2.5 six packs, during the build). Both are mech and lean towards road racing. I shall get spec's. I suspect 1+ of them would "like" ported TA's....... Cheers, roverman.
Dan Jones
Dan Jones
St. Louis, Missouri
(280 posts)
07/21/2008 03:32PM
Date: July 29, 2014 02:07PM
Sounds good. The short block should handle it. It's a 4.2L Rover that's been fitted with cross bolted main caps. Rover 3.03" stroke crank, narrowed Carrillo 6.200" H-beam rods with the optional SPS-CARR bolts, Wiseco forged pistons & rings (should be around 10.75 to 11:1 compression with the TA heads) and a steel flywheel.
When you get the specs, I'll run them through Dynomation for both the 4.2L and 5.0L Rover engines.
Thanks,
Dan Jones
Date: July 29, 2014 02:53PM
Using the Ferrea, hollow stainless valves ? Ovate wire/beehive springs ? Rev limiter ? I heard a horror story, of a "factory Leyland RV8, formula car", in privateer hands, missed a shift/bounced the lifters, and ripped the lifter bores, out of the block ! Not as likely on a dyno, but vital in the street/track world. Cheers, roverman.
Edited 1 time(s). Last edit at 07/29/2014 02:59PM by roverman.
crashbash
david bash
st. charles
(215 posts)
01/28/2008 10:53AM
1979 MGB Rdst V8 project, 1968 MGC GT, 1969 MGB Rd olds 215
Posted by: crashbash
Date: July 29, 2014 08:55PM
Art,
How much hp /torque did the Huffaker engines make? What are all the good stuff they are made with, considering their budgets?
Date: July 30, 2014 11:14AM
David and clan, back in the day, even in GT 1, the engines were limited to oem blocks/heads.stock crank, Carrillo rods, Ross pistons(heavy),ported stock heads, with ti valves,flow appox 190 cfm/int.@ .6", and .55" lift mech. roller cam. Joe Huffaker Sr., said the motor made 350 hp., (a good sales figure). I never dynoed the combo, but at SCCA driver school/ RIR, 85" of wheel base and as a novice driver, overrun with adrenaline, it made for a "very" lively package. Onward, roverman.
(4514 posts)
Date: July 30, 2014 02:21PM
Dan, is that Wiseco piston a custom?
Dan Jones
Dan Jones
St. Louis, Missouri
(280 posts)
07/21/2008 03:32PM
Date: July 30, 2014 06:11PM
Yes, it's a flat top with deep valve reliefs. Pin location is altered to suit the change in connecting rod length.
Dan Jones
