limey222
Michael Cubbon
Portland, OR
(129 posts)
08/01/2015 12:55PM
1969 MGB GM 3.4L V6
What brand of replacement fuel injector should I buy for my 94 Camaro 3.4L motor
Posted by: limey222
Date: September 30, 2017 08:32PM
I'm looking for some opinions based on real experience. I've determined that I have leaky injectors and I want to replace all 6. there is a huge price range, Delco running around $600 thru Standard at around $330 to Accel at around $250. I would expect no problems with the Delco's but i would like to save a little money. How is the Standard product?
Also if I go on to a site like Summit and enter my engine or model details it recommends a certain part number. To make maters more complicated some brands like Accel also have a choice of ratings lbs of fuel power hour. I used one of the formulas basing my HP at 180 and it seemed to recommend 19lbs/hr injectors. The other brands like standard doesn't quote a rating.
I've been leaning towards buying thee Standard FJ95's at $56 each, Summit listed them for a 94 3.4L V6 engine.
Any help would be appreciated, I've never replaced them before and I would like to order them this weekend.
(4615 posts)
Re: What brand of replacement fuel injector should I buy for my 94 Camaro 3.4L motor
Date: September 30, 2017 10:43PM
Another source:
[www.rockauto.com]
MG four six eight
Bill Jacobson
Wa state
(326 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: October 01, 2017 01:18PM
Michael,
Unless the coil is shorted or open most injectors can be saved (even if they are dripping/leaking) by ultrasonic cleaning them,
I have had very good success having them cleaned by Witch Hunter Performance [www.witchhunter.com] They will even send you a sheet that has the before and after flow rates of each injector.
Witch Hunter is located here in WA state, so they are fairly close to you to save on shipping time,
Bill
Edited 2 time(s). Last edit at 10/01/2017 01:21PM by MG four six eight.
(4636 posts)
Date: October 01, 2017 08:46PM
I had good luck with having injectors cleaned too. This old thread shows what the report looked like:
[forum.britishv8.org]
(2632 posts)
Date: October 02, 2017 07:15AM
Michael, I've read some guys like the Bosch type 3 style injectors. Yellow, 19lb for 5.0 Ford V8. Supposedly more reliable and better spray pattern than the GM injectors.
