Re: Electric power rack steering
Just finished an install into a Volvo p1800.
It transformed the car! Was a complete bear to drive at low speeds and during parking. Now it's a pleasure to drive. Couldn't be happier. Should have taken pictures during the modification but didn't have my camera here yesterday. Remote mounted the control unit and flipped the assist unit upside down so that the pedals had max clearance. Took an afternoon including some time on the lathe. Will definitely do it again. Fit well into a car with no room. Cheers Fred |
05 Equinox
Capt'n Moorgone Mike Moor Angola,IN (116 posts) Registered: 11/20/2008 07:05PM Main British Car: 1973 MGB 300 Buick |
I haven't seen anything yet. I have about 5000 miles on mine this summer. You get used to it pretty quickly. The VSS could help the over 45 mph cruising. Definitely need to be careful in the early cars with the quicker rack ratio. I still get a smile on my face when driving!
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (6591 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
What exactly does the Bruno box do?
It has a pot, it has power. Does it do any more than just send a variable voltage? Jim |
MGBV8 Carl Floyd Kingsport, TN (4630 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB Buick 215 |
So a pot and a chip, but we don't know what the chip outputs to the controller. Could be a complex waveform, could be a reference voltage. Or anything in between.
Too bad somebody hasn't been able to put a scope on the output yet. There are just two wires going to the controller. Two wires from the pot to the Bruno, a hot wire and a ground. The Bruno was described as, "having a small chip" (which these days might not mean much).
I have a bit more than an academic interest. On my bench is sitting an electric power steering pump which I thought could be a good portable source of hydraulic power, like maybe for a tubing bender or something. But it also has inputs for control. Interestingly enough the built-in controller takes DC and creates a 3-phase current to power the motor so just wiring it direct would not work. Probably a waste of time and money to mess with it and I may end up throwing it away but I was curious enough to pick it up at the junkyard, and to take it apart. Jim |
Lots of great info on EPS/EPAS. Backs up Fred Key on not needing the Bruno module.
[www.forabodiesonly.com] Edited 1 time(s). Last edit at 11/22/2016 07:01PM by MGBV8. |
Scott68B Scott Costanzo Columbus, Ohio (569 posts) Registered: 10/25/2007 11:30AM Main British Car: 1968 MGB GM 5.3 LS4 V8 |
Sh!t, I'm running out of excuses for putting this off!
Great info Carl! Are you considering it? |
Great info Carl!! Thanks for finding and sharing. Looks like no more excuses not to transform your driving experience! It'll make you faster through the Mountains!
They were discussing it over on the main MG Experience. Someone linked that page. I was amazed at all the info there. Figured it need to be here, as well. ;)
That could work out really good. I've been driving the RM with the Bruno dial set in various positions and have just about settled on 3/8 as being the best setting. 1/2 is also good. So if those other units in limp mode run at about 1/2 it should be a good set up. Although you CAN vary the setting for different driving conditions, in a very practical sense it is best to find one setting that will work acceptably well for all conditions and just leave it there, and that is exactly what most drivers will do.
I had not noticed the lack of centering but next time I drive the car I will check it out. Considering the light weight of the car, one of the two smaller units should work well, hard to say yet which might be the better choice. But few new cars are in the 2100-2500 lb weight range, or even sub 2700 lb. That should be a consideration when selecting a unit, as should steering rack ratio or turns lock-to-lock. Perhaps the turns should be a divisor of the weight in making a comparison. That would give us some real numbers that we could use. Jim |
Since this is THE main thread on EPS/EPAS, I am cross-posting this from the Triumph section thread.
Quote: Edited 1 time(s). Last edit at 11/23/2016 12:16PM by MGBV8. |
