(4636 posts)
SOLD! --- Ford 8.8 axle, already narrowed for MGB! 3:27:1. Traction-Lok. Excellent Condition.
Date: March 05, 2025 10:28PM
This is the Ford 8.8 axle from my MGB GT V8.
It always performed fine. I just want a whole different rear suspension and axle solution now.
This axle was originally installed in a 1992 Ford Mustang GT. As I recall, I purchased the axle in early 1994 from a local junkyard and immediately had its housing professionally narrowed by a local shop (both in Greensboro NC).
Axle shafts were shortened and drilled for half-inch lugs on a 4x4.5" (i.e. stock MGB) pattern by Moser Engineering. (Note: the Mustang's 4x2.25" pattern could alternatively be used, if you want to change lugs.)
Axle shaft length and spring perch placement are symmetrical. Assembled axle width is 52.25", wheel-to-wheel.
I believe the Traction-Lok differential is still in "barely broken in" condition. I never felt any need to rebuild it, or mess with clutches/shims, or try alternate fluid. It doesn't make any weird noises. I wasn't exactly stressing this axle.
This axle comes with Ford drum brakes. At some point (~2010) I swapped-in Ford Ranger wheel cylinders to get a little more rearward bias. I'd advise the new owner to plan on doing a brake rebuild because it's been 10+ years since the last one. Or you could convert to disk brakes. I'm sure kits are available.
As you can see in the final photo, I'm including many usable spare parts for installation of this axle in an MGB. Those might save you a lot of time and money.
Free delivery within Portland Oregon. Or just come and get it! It's a lovely time of year for a visit.
$500, firm.
Best way to contact me is via personal message on this forum.
Edited 2 time(s). Last edit at 06/08/2025 02:04PM by Moderator.
(4636 posts)
Re: Ford 8.8 axle, already narrowed for MGB! 3:27:1. Traction-Lok. Excellent Condition.
Date: March 05, 2025 10:39PM
A few more notes:
1) I put the hydraulic brake connection in the same place as stock MGB.
2) axle has a bracket welded to it for a Panhard rod. (Let me know if you want more info about that.)
3) last photo: those aluminum wedges are for adjusting pinion angle to parallel with engine. Whether or not you need/want them depends on how your engine is installed. Other angles are readily available.
4) you can tell from the shock brackets that I welded (grade 8) bolts on for use with telescoping shocks...
Scott68B
Scott Costanzo
Columbus, Ohio
(569 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: March 06, 2025 07:53AM
Curtis,
Great deal for a bolt-in axle!
Hope you're going to share your new project!
Scott
(4615 posts)
Date: March 07, 2025 10:37AM
What does it weigh, Curtis? I will add your numbers to this thread:
[forum.britishv8.org]
(4636 posts)
Date: March 09, 2025 04:34AM
Of course! But I'm not quite ready to show those cards yet. As a teaser, I've just posted something about a precursor project here
I prefer to focus on it's excellent (3.27:1) gear ratio and it's delightful Traction-Loc differential. I tried to weigh it, but my electronic freight scale broke. No kidding. But I don't think it broke from being overloaded. Something went wrong with the LCD display. I've ordered a brand new scale, so I'll get a weight when that arrives. And of course I'll weigh my new solution too when it's all together.
(4636 posts)
Date: March 19, 2025 09:21PM
Lighter than I expected: 169.6#
That’s complete as pictured in the first two photos above, without u-bolts and other mounting hardware.
ag1234
Arthur Gertz
(156 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: March 24, 2025 08:01PM
Has anybody here broke an 8"ford ?
Art.
(4636 posts)
Date: March 25, 2025 02:26AM
I'm pretty sure either size axle is sufficiently robust.
However, Ford hasn't installed an 8-inch in about 39 years. They're not as readily available as they once were.
The 8.8 I'm selling is in excellent condition, it's ready to install in an MGB, and it's a great deal!
(4615 posts)
Date: March 31, 2025 06:37PM
Yes, it is! If it were not 2600 miles away, I would be all over it.
Spitfire 350
Phil McConnell
Perrysburg, OH (Toledo area)
(259 posts)
01/11/2010 09:19PM
74 Spitfire 350Chevy
Posted by: Spitfire 350
Date: April 01, 2025 04:15PM
Has anyone checked into shipping it? I would think LTL would be less than $500.Old Dominion, R&L, Schneider????
(4615 posts)
Date: April 02, 2025 05:14PM
I had a Rover 3.9L engine on a pallet shipped from the D.C area to the loading dock of the company my sister worked for in Johnson City, TN for $100. Thought that was reasonable. Way pre-COVID, though.
(4636 posts)
Date: April 26, 2025 04:38PM
The axle is still available and still incredibly bargain priced!
I’m willing to think about putting it on some sort of pallet and dropping it off at an LTL trucking terminal. “Saia” and “Old Dominion” are pretty convenient to me, though I haven’t used either. Buyer would have to work out all the shipping details.
(4636 posts)
Date: May 22, 2025 12:48AM
The axle is still available.
If you buy it this weekend, I'll throw in the set of Lokar parking brake cables I used with it.
(4636 posts)
Date: May 24, 2025 03:23PM
I can even throw in a driveshaft flange and perfectly good Spicer 1310/1330 conversion u-joint, which might save you even more money. This axle is a great deal! But it’s got to go now. It’s in my way.
(6569 posts)
Date: May 25, 2025 08:24AM
That *is* a great deal and somebody really needs to jump on it. Just the posi would cost more than that new.
Also, the drum brakes are a great option. Wider than stock which already do quite well in a conversion and the self actuating characteristic of drum brakes means the handbrake will always be more effective than with a rear disc brake conversion. Folks don't realize it but in this case the older technology is actually better.
(4636 posts)
Date: June 02, 2025 02:46AM
I've just re-measured the axle width (from wheel mounting surface to wheel mounting surface) with a tape measure and with the axle sitting on dollies as pictured above, and the measurement I'm seeing tonight appears to be 52 7/16". Buyer should probably round that up to 52 1/2" to be prudent. (With wheels actually bolted tightly on, the width might really be 52 1/4" as my notebook says.)
I sketched up a shipping pallet that I can make for $50. In addition to lumber and screws, it uses the two dollies shown in the photo and the axle would be secured down with u-bolts. The pallet's footprint would be 60" x 20", and the total height of axle and pallet would be about 13". My design leaves 2" gap for a pallet jack's fork to slide underneath in the middle. I think that's enough, but a buyer might want to confirm.
I received a question about how well the parking brake on the Ford axle works. When installed on my MGB, it worked fine as a parking brake but wasn't suitable for "emergency brake" stops. It certainly wasn't sufficient to lock-up the tires at speed. However, I'm not sure how much of this issue is attibutable to Ford's design. I DID lengthen my original MG lever arm somewhat to get more cable travel per pull, but I may not have gotten the length or geometry quite right.
I don't know how much longer I'm willing to trip over this thing. I don't have storage space. It's in my way, and one way or another it's got to go soon.
Edited 2 time(s). Last edit at 06/02/2025 02:49AM by Moderator.
