WVStag Earl Arentz West Virginia (1 posts) Registered: 02/10/2018 03:58PM Main British Car: Triumph Stag Triumph 3.0 V8 |
Re: Introduce Yourself Here!
Hi,
My name is Earl, and live near Huntington, West Virginia. I have really enjoyed learning of about your cars and projects, and know that membership here will be an asset in my projects. My primary interest is in Triumphs and have had experience with them on and off since high school. I presently own a TR6, TR7s, and a Stag with the original 3.0 V8. The Stag has been off the road for about 10 years, but looks like it could be resurrected with hopefully some relatively minor repairs. |
Earl, you are sandbagging a little wouldn't you say? (He has a whole yard full of TR7's and has been a luminary in the WVBSCC since it began.)
Anyway, good to see you here. Jim |
MiniCobra Mike B Weatherford, Texas (1 posts) Registered: 11/12/2016 11:56AM Main British Car: 1973 MG Midget Ford 302 V8 |
My MG Midget was purchased in September 2016. The car had been in the previous owner's family for 30 years.
The original engine went bad so they made a few modifications. The project was performed by a retired A/P aircraft mechanic, who worked to engineer the project. Some of the modifications include: A rebuilt 1968 Ford 302 V8 with an Edelbrock cam kit and manifold with Holley 600 CFM 4 bbl carburetor mated to a fully rebuilt C4 3 speed automatic with a B&M shift kit. Dash, Interior, and Top fully replaced at time of full restoration and motor rebuild. Front suspension was beefed up and brakes had recently been redone with new master cylinder, new rear cylinders, and rebuild kit on the front calipers. Car is fitted with wider than stock 13" wheels and upgraded wheel studs. Rear axle was originally a rebuilt stock 3.90-1 MG Midget unit. The original project was completed over 25 years ago and still shows quite well. The odometer showed 69114 miles at time of restoration but was replaced and showed only slightly over 850 at time of purchase and since full rebuild.The car has always been stored indoors in a climate controlled shop. Since purchasing the Midget the radiator fan has been upgraded, broken radiator cap replaced, water pump bypass hose replaced, the speedometer gear corrected, the tachometer repaired, the carburetor tuned, replaced battery and charging system repaired, voltmeter installed, 15 gallon RCI fuel cell and fuel level gauge installed and high voltage electronic ignition installed . A custom narrowed Ford 7.5 inch limited slip rear axle was installed over the summer of 2017 to eliminate the fear of axle breakage and improve highway rpm using a 2.73 ratio. At the same time rear springs from a 1500 model were installed as well as custom made anti tramp bars and Acura Integra rear disc brakes. A broken transmission mount was discovered and replaced about this same time. The radiator puke tank was converted to an expansion tank to remedy coolant overflow. A top boot cover was procured and installed to improve top down cosmetics and gas lift struts were installed on the bonnet and boot. In early 2018 the ignition vacuum advance unit was found to be faulty and replaced. |
Mike,
Welcome to British V8!!! If there is any way you can make it to this years get together in Dayton, OH, we would love to see you and the car. That looks like an awesome vehicle. Phil |
Bmwrover Mark Van Lenten Pennsylvania (2 posts) Registered: 03/31/2018 07:57AM Main British Car: 1995 Land rover discovery 3.9 v8 |
Greetings from Pennsylvania! I'm working with my rover v8 in my 95 land rover discovery. the more and more i read about these motors the more i like the following they get! it has been a great truck for the family and i'm currently rebuilding the motor and have some questions for the group.
Hi, My name is Gary, and although I do not currently have a British V8 I'm interested. I currently own a '74 MGB and a '71MGBGT. I'm slowly bringing them both back to life and making them roadworthy. I'm interested in the BV8 meet in Dayton. Will there be any vendors there to talk with about a V8 conversion? Do I need to register for the meet ? Is there a cost to register? Can I just show up to check out the cars and mingle with the owners?
Edited 1 time(s). Last edit at 06/11/2018 10:03PM by garydlowrie. |
Just show up Gary, you will be warmly welcomed and go home with more information than you ever thought possible.
Hi everyone! Im Erik from Stockholm, Sweden. Im going to GB in a couple of weeks and hope to get updated on upcoming events, meet-ups and such on this forum. Take care!
Edited 1 time(s). Last edit at 06/21/2018 05:31AM by EWN64. |
Welcome Erik & Adrian.
I am a big Chevy fan. Drop in over here, so we can discuss this further. [forum.britishv8.org] |
Will do as I have a lot of questions and thanks for the welcome
svomgb Dennis Ogden Niwot, CO (7 posts) Registered: 08/17/2012 02:04PM Main British Car: 1967 MGB roadster 85 ish Ford 2.3 turbo 20 psi boost |
Hi my name is Dennis. Curtis introduced me to this site a few years ago when he came into my store in Longmont, CO. I have a 67 MGB roadster with a 2.3l Ford turbo engine. In its current state it has approximately 250 horsepower and is a total blast to drive. I'll put up some links in the build forum.
Welcome Dennis. Nice car and appears well done. But in case you didn't know, readers can't comment on journal threads. So if you want feedback you'll need to put something in the MG section.
ainadude Jeff Nicolay Indian Wells, Calif. (20 posts) Registered: 03/31/2012 11:23PM Main British Car: 1976 Triumph Spitfire 1993 Mazda Miata (1.8 liter/5spd) |
Hi guys (and, pardon my sexism, girls)
My name is Jeff and I've posted a couple of times in the Triumph section. I have a long-languishing '76 Triumph Spitfire ("Mrs. Peel") with a '93 Miata 1.8L/five-speed under the hood. (If you want to get up to speed on the whole debacle, please check out my handful of posts in the Coventry neck of the woods.)
Some quick stuff about me; Am on the downhill slide to 60 yo and grew up in the Kansas City area. Lived most of my post-college life in Honolulu but just moved to Indian Wells, CA, where I had bought a small investment property several years ago (i.e. my new home). Have worked in media my entire life ... first in radio, then for many years in print before going back to the former and finishing my time in the Islands doing on-air news. Currently work out of my home in the Golden State writing copy for NBC Radio on a part-time basis (sadly, good media jobs have gotten scarce in the Internet age, especially if -- like me -- you're not a black belt in social media). That being said, I do have a question for the group, especially for any of you who call California home. How do you go about registering a post-1975 British sports car with a non-stock engine? I've got about another six weeks on my Hawaii registration, and need to make a decision about keeping her or putting her up for sale. I'd prefer the former, but there are only so many hoops through which I'm willing to jump ... Appreciate any substantive feedback ... and God bless all of you for keeping these charming cars on the road. Aloha and mahalo, Jeff Edited 1 time(s). Last edit at 08/20/2018 09:31PM by ainadude. |
MGB SS Joe Schafer Central Michigan (150 posts) Registered: 10/23/2007 06:46AM Main British Car: 1971 Mgb 1991 5.0 Ford |
Jeff
post this in the British pub under a new topic, you will get a lot more traffic that way, as to California I am not any help I am at the other end of the country good luck Edited 1 time(s). Last edit at 09/09/2018 01:43PM by MGB SS. |
murray.arnold murray forbes-arnold croatia (16 posts) Registered: 09/13/2018 01:25AM Main British Car: 1973 MGB GT ROVER 3.5 V8 |
hi guys. New member here
Good day all.
My name is Murray. I am from Scotland, live in Croatia and work in Kuwait. I own a 1973, 3.5 V8 MGB running an auto box. I have owned the car now for about 6 years. I bought the car with only 17k on the clock and drove it from Scotland to Croatia on my first journey. Since then Its had a back to metal respray and new bright work. Along with a full stainless steel exhaust system and 4 barrel Holley carb. Once you've had an eight, the rest feel fake :-) |
